    Martial Masters Help
    martial masterspgmigs
    4 Posts 3 Posters 872 Views
    • U
      uneedkhoality
      Hello everyone, noobie here and trying to get Martial Masters to work on Retropie. I only can get Espgaluda to work. Demon Front and Martial Masters are the 2 I can't get to work in Retropie. I have a standalone mame0228b on my PC which runs all 3 games fine. I have the pgm.zip placed in the bios folder and the arcade/fba/mame-libretro folders trying to get it to run to no avail. What am i doing wrong? Any insight or suggestion would greatly be appreciated. Thanks!
        Please add more info about your setup and error, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        Your error seems to a common arcade game error - you're using the wrong ROM for the arcade emulator. Take a look at https://retropie.org.uk/docs/Arcade/, then make sure your ROM matches is from the correct romset used by the emulator.
        B U 2 Replies Last reply Reply Quote 1
          barbudreadmon @mitu
          @mitu said in Martial Masters Help:
          wrong ROM
          and/or bios in the case of pgm
          • U
            uneedkhoality @mitu
            @mitu Thank you, i will look at the info you provided.
