    Bluetooth RetroPie Setup Script Issues
    bluetoothraspberry pi 44.7.18bitdo
    44 Posts 10 Posters 9.7k Views
    • L
      loopsheloop
      Hi, I was about to post this exact topic.
      I tried with an SN30 Pro and a Switch Pro and am experiencing the same problem - the setup utility freezes when selecting a security mode.
      Pi Model or other hardware: Raspberry Pi 4B
      Power Supply used: Canakit Pi 4
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.7.1
      Built From: Pre-made image from website
      USB Devices connected: USB storage stick, keyboard
      Controller used: 8BitDo SN30 Pro, Switch Pro controller
      Occasionally after the failed pairing I'm unable to remove the device:
      Restarting the Pi seems to fix this.
      EDIT:: Found a workaround from this thread on the official forums:
      https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=304000&hilit=Bluetooth&start=25
      At the command line, type these commands:
      sudo systemctl daemon-reload
      sudo systemctl restart bluetooth
      Then restart emulationstation and go to Bluetooth config. This allows me to pair and use the SN Pro. Rebooting breaks it again, but you don't need to re-pair - type the above into command line again, then go to Connect all paired devices in the Bluetooth config and make sure your controller is on.
      EDIT 2:: "Pair all Connected" isn't working very well for me anymore. For best results, after every reboot, restart the daemon/bluetooth service, remove the paired device, then pair again. This also will fail occasionally; it seems like if I get the org.bluez.error screen on a boot, nothing will get it to work. Try rebooting again.
      mituM 1 Reply Last reply Reply Quote 1
        mitu Global Moderator @loopsheloop
        @loopsheloop said in Bluetooth RetroPie Setup Script Issues:
        What Pi4 model do you have ? Can you run cat /proc/cpuinfo and post the output ?
        • L
          loopsheloop @mitu
          @mitu said in Bluetooth RetroPie Setup Script Issues:
          It's the Pi 4 B. Results look pretty similar to the one previously posted:
          2 lines that the console remembers isn't the worst workaround I've ever dealt with :) Thanks for looking at this!
            It's the Pi 4 B.
            Just wanted to confirm this is a 1.4 model (last line) - thank you. Looks like it's not an issue with older models (as @pscotto1234 also noticed), I'm wondering what's different in 1.4 vs older models during the Bluetooth start-up that requiring a restart of the bluetooth service necessary.
            I have one of the older models (1.1) and can't seem to replicate this either with my current install or with a fresh one.
            • V
              velez66
              Okay, here is what I have some far.
              Bought the Bluetooth adapter. Was able to connect my 8BitDo SN pro+ Worked for a few reboots. Then stopped working completely. Unpaired tried to pair.
              Then get the error - “ bluetooth device (Creating device failed: org.bluez.Error.AlreadyExists:already Exists)
              Any ideas. Thanks
                mitu Global Moderator @velez66
                @velez66 Did you disable the onboard Bluetooth after connecting the dongle ?
                Also, the 8Bitdo gamepads have a tendency to not reconnect when you're just rebooting the Pi - usually powering them off and on is enough for them to re-connect.
                • V
                  velez66 @mitu
                  @mitu Hello - Yes I did. Also reboot and did a complete power off.
                  Note: I am using a NESPi 4 CASE, which I have heard that the SSD feature creates interference with the onboard Bluetooth.
                  It might be affecting the Bluetooth dongle that I bought
                  Going to try the Bluetooth dongle on my Argon case to eliminate that possibility and for troubleshooting
                  Help and input it is appreciated.
                  Thanks a lot!!
                  • V
                    velez66
                    Okay, got it to work on the Argon Case using the Bluetooth Dongle. Not sure if I am going back to the Retroflag Nespi 4 Plus and try again. The Nespi Case is really nice.
                    • V
                      velez66
                      Well back to the error again. Extremely frustrating.
                      Worked for a few hours. Shutdown the system for the night
                      And today it doesn’t recognize the controller again
                        jtcuth48 @velez66
                        @velez66 did you press "Set up udev rule for Joypad" when you got it to connect last time? If you don't do that with 8bitdo controllers they won't be recognized after a reboot.
                        • V
                          velez66 @jtcuth48
                          @jtcuth48 Yes I did 😊 Thanks
                            Ttazer
                            Thank God for this thread, can't find anything anywhere I was going crazy, new pi 4 8gb, couldn't add 5 different expensive Bluetooth devices, froze everytime at same screen, 3 days of beating my head into a wall until I stumbled until this thread, bless you all!! Definetly an OS problem.
                              jtcuth48 @Ttazer
                              @ttazer yeah, definitely a disconnect between the OS and the newer Pi 4 boards, because I've had a couple friends with older Pi 4 boards say theirs' was fine. Hopefully it's something that can be resolved in the future through a software update instead of a hardware update :)
                                pscotto1234 @jtcuth48
                                @jtcuth48 said in Bluetooth RetroPie Setup Script Issues:
                                I hope a software update can resolve. Other system like recallbox works fine with Bluetooth.
                                • V
                                  velez66
                                  It is the board + OS. Yep
                                  • L
                                    loopsheloop
                                    Edited my original post as Pair all Connected is pretty hit and miss. Re-pairing every time you reboot seems more effective, but still fails sometimes. If you've got it in a working state, I'd recommend just leaving the Pi on if possible.
                                    • H
                                      hopkingreenfrog
                                      Joined to chime in with the same issue, except my Raspi4 (4GB) is a v1.2, according to cat /proc/cpuinfo. It's a new board, and loaded with Retropie 4.7.1 with all updates installed. It was freezing with a 8bitdo N30 Pro on the security mode selection, never connecting. I was able to get it going with the fix listed here:
                                      https://raspberrypi.stackexchange.com/a/123914/131922
                                      Afterwards, though, I got a couple of intermittent crashes on shutdown with the bluetooth stack. Ordered the usb bt dongle listed above from Amazon. Rolled back the fix and disabled the onboard bt, and it seems to be working consistently fine now across multiple reboots. Seems to connect smoother than with the fix installed, actually.
                                      • L
                                        loopsheloop @hopkingreenfrog
                                        @hopkingreenfrog said in Bluetooth RetroPie Setup Script Issues:
                                        Thanks for finding this! While going through it, I found examples of similar problems going back to to 2018 on a Pi Zero.
                                        After editing bt.helper, my SN 30 Pro seems to be working as intended (I think): after loading Emulation Station, the controller would pair itself when I powered it on. Tested with 2 reboots and 2 cold boots. I wonder why your device started crashing.
                                        • H
                                          hopkingreenfrog @loopsheloop
                                          Not sure about the crashes on shutdown, but it was only once or twice across 10-15 reboots/shutdowns. Chalk it up to a buggy bt implementation, I suppose. Still no issues with the bt dongle, though. Received one of the new 8bitdo Pro 2 controllers yesterday. That's working well with the dongle as well.
                                            rafaz182 @link3384
                                            @link3384 Here, for you https://github.com/RetroPie/RetroPie-Setup/releases/tag/4.6 :)
