    Bluetooth RetroPie Setup Script Issues
    bluetoothraspberry pi 44.7.18bitdo
    44 Posts 10 Posters 10.6k Views
      spaceace
      Hi, All.
      Thank you for this thread. I found it AFTER I clicked the button to order my controller! I now have the 8BitDo SN30 Pro+ controller working flawlessly on a Raspberry Pi 4B, with RetroPie 4.7.1 on updated OS.
      Before I attempted to pair, the pad was connected via USB to the Ultimate Software application for a firmware update. I also configured a Switch profile, with star(★) as turbo button.
      I followed these steps before pairing, too. I consider these safe steps, as it only disables an unused SIM card driver and delays bluetooth start for two seconds at boot.
      So, then...
      $ sudo nano /lib/systemd/system/bluetooth.service
      $ sudo nano /lib/systemd/system/bthelper@.service
      $ sudo rm /etc/udev/rules.d/99-bluetooth.rules
      $ sudo reboot
      $ sudo /home/pi/RetroPie-Setup/retropie_setup.sh
      Configuration / Tools -> bluetooth
      hack OFF
      power on controller by holding Y + start one second (Switch mode)
      hold in pair button for three seconds
      leds will rotate like knight rider
      Register and Connect to Bluetooth Device
      on "Searching" screen, pressing some buttons can help
      choose "Pro Controller"
      DisplayYesNo
      Setup the udev rule
      hold start three seconds to turn pad off
      reboot
      turn on controller
      configure input
      GOOD
      I have the pad in Switch mode. To select the profile with turbo, press both sticks (L3+R3) and the heart/home button will light up. Hold a button and press star(★) to enable/disable turbo. It will stay in Switch mode with profile, so now all you have to do is hold the start button to turn it on or off.
      Hope that helps. Cheers.
      P J 2 Replies Last reply Reply Quote 0
        pscotto1234 @spaceace
        @spaceace said in Bluetooth RetroPie Setup Script Issues:
        Hi, All.
        So, then...
        $ sudo reboot
        hack OFF
        DisplayYesNo
        Setup the udev rule
        reboot
        turn on controller
        configure input
        GOOD
        It works fine Smith DS4. Later I'll give it a try using a sixaxis controller.
        @spaceace thank you so much!!!
          jtcuth48 @spaceace
          @spaceace Wow, perfect! Thank you so much, I'm glad the issue has been figured out. Hopefully the OS team is aware of this issue and gets it fixed for a future update. Thanks again!
            pscotto1234 @pscotto1234
            @pscotto1234 said in Bluetooth RetroPie Setup Script Issues:
            Hi, All.
            So, then...
            $ sudo reboot
            hack OFF
            DisplayYesNo
            Setup the udev rule
            reboot
            turn on controller
            configure input
            GOOD
            Sixaxis works as well!!!
            • M moody31415 referenced this topic on
