    Updated to RP 4.7 and now my A1up volume slider won't mute.
    arcade1up
    5 Posts 2 Posters 641 Views
      Drifty
      I wired my A1up gen1 3 position switch to my Pi and never had a problem until I upgraded to RP 4.7, I ran my scripts again and the power switch is working as it should, but the volume switch won't mute, it's either quiet, loud, or very loud.
      I'm not sure how to fix this? Thanks
      Power Supply used: USB power from 12v to 5v converter board from 12v 5.3a brick
      RetroPie Version Used : 4.7
      USB Devices connected: 2x Dragonrise USB Encoders
      Controller used: none
      Error messages received: None
      File: I run this script with previous versions of RP (my volume switch wiring goes to pins 14 red, 16 white, 18 blue).
      bash <(curl -s https://raw.githubusercontent.com/orlandovald/arcade1up/master/setup.sh)
        Please add more info about your setup, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
          Drifty @mitu
          @mitu said in Updated to RP 4.7 and now my A1up volume slider won't mute.:
          Done, thank you.
            mitu Global Moderator @Drifty
            @drifty If your issue is with the audio switch from https://raw.githubusercontent.com/orlandovald/arcade1up/master/setup.sh, then you should direct the question to its author(s).
            Otherwise, if the issue is with EmulationStation's volume control, then take a look at this topic and see if it makes a difference.
              Drifty @mitu
              @mitu Yep, been through all that already, I don't know what the deal is. I will take your advice and ask the author if he knows about it not working with 4.7.
