    controller issues in rom
    help
    2 Posts 1 Posters 267 Views
      retronaff
      Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..) Ubuntu 20.04 on server
      Power Supply used: (If using a Pi)
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.2
      Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used) retro official git
      USB Devices connected:
      Controller used: ps4
      Error messages received:
      Verbose log (if relevant):
      How to replicate the problem:
      Hi Everyone -- I am using ds4drv to connect my ps4 controllers and they work fine in the menu.
      When i start a rom, two menu overlay's pop up and say 'sony controller connected' and my controllers don't allow me to press start or any button. The Rom's just sit there and play their splash screen and I have to manually ctrl+alt+delete my keyboard to shut down my retropie.
      Once again, my ps4 controller pairs fine and I'm able to map the controller and search the menu just fine but once I start a rom in NES I cannot play the game or even exit the rom using start + hotkey.
        retronaff @retronaff
        @retronaff i figured it out -- if you have a keyboard plugged in, you need to go into your RA settings and change your joystick to your Playstation controller instead of keyboard.
