    Disable PS3 controller rumble lr-pcsx-rearmed
    29 Posts 13 Posters 17.1k Views
    • Beretta9B
      Beretta9
      Retropie 4.0
      Pi 3
      PS3 controllers wireless
      Somehow I've enabled the rumble function within
      The PlayStation emulator. Every time my controller try's to vibrate, emulation starts stuttering.
      How do I disable this function?
      Retro Gamer Supreme
      • Beretta9B
        Beretta9
        Anybody?
        Retro Gamer Supreme
          mediamogul Global Moderator @Beretta9
          @Beretta9
          If you're using lr-pcsx-rearmed, you would bring up the Rgui menu by pressing select+x. from there, go into the 'Quick Menu' and the 'Options'. You should find the setting in there.
          Edit: I have to note that the rumble addition is so new that I haven't really confirmed this myself. It could be that it's just always on, but I would doubt that.
          • Beretta9B
            Beretta9
            @mediamogul I formatted my sd card yesterday, so I'm on a fresh install of retropie 4.0 rc1. First thing I did was load metal gear solid and set my pad type to analog, the rumble is there, so I can confirm that this is enabled be default. I've been all through the retroarch menu and I cannot find any settings for vibrate or rumble.
            Retro Gamer Supreme
              SOSretro
              I have the same problem. Rumble causes any game to stutter. It used to be that if the controller was standard it wouldn't happen and with analog it would enable rumble. I would just keep it on standard to avoid the problems. Latest version of RetroPie updated through setup, rpi3, over clocked, running ps1 roms from a USB HD.
              Would love to know how to turn this off. I would keep it if it didn't cause the game to skip.
              • F
                Fenthor
                I think this problem only happens with a ps3 controller, cause i have the same one. I tested with a psx controller connected via usb and games work fine without stuttering, BUT rumble doesnt work, even with analog mode ON. Do you have another controllers for testing? Maybe I have a problem with psx controller as well...
                  SOSretro
                  Yup, seems to only happen with my rumble capable controllers (all PS3). My ps1 controllers work fine, though I'm tethered to the consol then :/
                  I tried updating PSX reararmed since it seems like there was a commit to fix this. Didn't do the trick.
                    SOSretro
                    Where should we post this issue? Pull request in the psx-rearmed GitHub project? Is it possible it is fixed but just not getting grabbed in the RetroPie setup script? I tried updating from the source and it still didn't fix it.
                    Googled if there was a setting to change the retro arch config file and not dice there either.
                      dankcushions Global Moderator @SOSretro
                      @SOSretro could you please log this issue here - https://github.com/libretro/pcsx_rearmed/issues
                      it sounds like
                      1. there should be a core option to turn rumble on/off, especially if it causes problems. otherwise you can't use analog mode.
                      2. the lagging whilst rumbling should be fixed. maybe @alexis-puska can help? :)
                        alexis-puska
                        I don't have a PS3 controller for the moment... i can't test, i will look in few day to get someone of my friend have a ps3 to make some Test. i'm not the last dev on the controller features. when i have developed this features, i test with a ps3 controller, i don't see any stuttering. What kind of stuttering have you ? display stuttering ? stuttering in the movement of the player ?
                        Did you used your PS3 controller with USB or bluetooth ? Did you have installed the driver for PS3 controller ?
                          SOSretro @alexis-puska
                          @alexis-puska Thanks for the reply! I'm using Bluetooth with the PS3 controller. The whole game stutters with the lag. It's most apparent on games with a lot of movement like crash team racing or cool boarders. There were some moments in CTR where the screen would freeze for a second or two, others times just momentary. I'm pretty sure I used the PS3 driver when I first set them up, however I'm going to double check to be sure.
                            alexis-puska
                            Did you used the option for graphical amelioration ?
                            edmaul69E S 2 Replies Last reply Reply Quote 0
                            • F
                              Fenthor
                              I have recorded a video showing the issue. I did it with Medievil cause its rumbles while you are running and you can see it better. I have enhacement graphic active, but i tested having it disabled and do the same thing. Sorry about bad quality :P
                              http://dai.ly/x4pxr6z
                                edmaul69 @alexis-puska
                                @alexis-puska i have retropie 4.0.1 and i cannot get rumble to work at all on a ps3, ps2 and ps1 controller. Before my old card died i was on 4.0 beta 2 and also updated retropie-setup to rc1 and downloaded lr-pcsx-rearmed and could not get rumble to work on those either.
                                  @alexis-puska i have the issue without the enhanced setting. I checked and I didn't have the PS3 driver installed, I tried installing it and had the same issue. I had a previous backup on 3.8 and after restoring it didn't show the issue. Appreciate your help!
                                    Junglist
                                    @alexis-puska
                                    I also have the issue with stuttering when rumble occurs, basically I would just use standard mode as I used to get stuttering on analog. Never realized it was the rumble but now that makes sense. Now something has changed that even when using standard I get the stutter.
                                    Any idea when this will be fixed? I saw the update that seems to fix it list as merged (https://github.com/libretro/pcsx_rearmed/pull/51) , but I ran an update on lr-pcsx-rearmed via both binary and source but still have the problem.
                                    • Beretta9B
                                      Beretta9
                                      Is there a solution to this problem yet?
                                      I am now having the problem even when analog is disabled. The only way I can stop the stuttering now is to go into the option menu in the game and disable vibration.
                                      Retro Gamer Supreme
                                        prosthetichead
                                        I'm having exactly the same issue on fresh install of RetroPie 4 using a bluetooth dongle with a PS3 controller. Crash Team Racing is best example rumble in game on and its lagging and has 1 sec lock ups when hitting water (biggish rumble) and if I go into the game options and disable rumble it's flawless and fast, zero lockups.
                                        Beretta9B 1 Reply Last reply Reply Quote 1
                                        • Beretta9B
                                          Beretta9 @prosthetichead
                                          @prosthetichead It seems like this is only effecting people using ps3 controllers.
                                          Like you said the only way to solve this problem is to turn off vibration within the game menu.
                                          Retro Gamer Supreme
                                          • X
                                            xwons
                                            Can confirm, also using a PS3 controller via bluetooth. This is specially present in games like Gran Turismo 2, where the controller is vibrating almost all the time. There's a small stutter for every little vibration.
