    Launch images do not work under Wayland without XWayland
    launch imagesruncommandwayland
    5 Posts 3 Posters 1.7k Views
    • ethelingE
      etheling
      Noticed that launching images won't work when running under 'pure' Wayland without XWayland being enabled (because fbi or feh wont run under Wayland). I'm on Ubuntu/x64 but I would guess it'll be the same on arm etc. platforms.
      Easiest 'fix' is to enable XWayland, but under Wayland/Sway feh appears to work a bit oddly not managing to always show the image fullscreen.
      I 'solved' this by adding imv Ubuntu package and by modifying runcommand. sh to use it under Wayland. Trouble is that there doesn't seem to be agreed upon way to reliably detect if one is running under Wayland. I think imv is also mainly intended for tiling window managers like sway/i3, and I didn't test it on stacking ones like Enlightenment, so I don't know how portable this is either. But at least on Wayland/Sway, it does work better than feh when XWayland is enbaled.
      Here's the patch for /opt/retropie/supplementary/runcommand/runcommand.sh in case anyone else bumps into this.
      1221,1222c1221,1231
      <         # if we are running under X use feh otherwise try and use fbi
      <         if [[ -n "$DISPLAY" ]]; then
      > 	if [[ "$XDG_SESSION_TYPE" == "wayland" ]]; then
      > 	    # if under Wayland use imv
      > 	    # alas, there appears to be no 'right' way to detect if we're on Wayland:
      > 	    # https://stackoverflow.com/questions/45536141/how-i-can-find-out-if-a-linux-system-uses-wayland-or-x11
      > 	    # https://unix.stackexchange.com/questions/202891/how-to-know-whether-wayland-or-x11-is-being-used
      > 	    imv-wayland -f -s full -x "$image" & &>/dev/null
      > 	    IMG_PID=$!
      > 	    sleep "$IMAGE_DELAY"
      > 	    imv-msg "$IMG_PID" "q"
      >         elif [[ -n "$DISPLAY" ]]; then
      • johnodonJ
        johnodon
        @etheling Funny you should ask this question and I just found it. :)
        I hit the same issue while running under KMS/DRM. My quick fix was to just use fbi the same as the Pi does and this works well. I don't know if it would work for Wayland.
            if [[ -n "$image" ]]; then
                    fbi -1 -t "$IMAGE_DELAY" -noverbose -a "$image" </dev/tty &>/dev/null
                    #feh -F -N -Z -Y -q "$image" & &>/dev/null
                    #IMG_PID=$!
                    #sleep "$IMAGE_DELAY"
                else
                fi
        Naturally, we probably don't want to be mucking with 'runcommand.sh' since the changes would be overwritten at next update.
        @mitu Is it possible to add another layer of logic to call the proper image viewer when running under Wayland or KMS/DRM?
        John
          mitu Global Moderator @johnodon
          @johnodon said in Launch images do not work under Wayland without XWayland:
          Probably - it would make sense for Wayland, for KMS/DRM not so much.
          johnodonJ 1 Reply Last reply Reply Quote 0
          • johnodonJ
            johnodon @mitu
            @mitu Thanks. Actually, I can just forego runcommand for launch images and use runcommand-onstart instead. This gives me total control. :)
            #!/bin/bash
            ROMPATH="$3"
            ROM_BN_EXT="${ROMPATH##*/}"
            ROM_BN="${ROM_BN_EXT%.*}"
            LAUNCHIMAGE="/home/pi/RetroPie/roms/$1/images/$ROM_BN-launch.png"
            fbi -1 -t 3 -noverbose -a "$LAUNCHIMAGE" </dev/tty &>/dev/null
            • johnodonJ
              johnodon @johnodon
              Now that I am back to playing with Wayland/Sway, I found the best solution is what @etheling was doing...using imv as the image viewer. The difference is that I am using runcommand-onstart.sh to display the loading screens so I don't have to mess with editingruncommand.sh. The key is to NOT name you launch images *-launching.png (I use *-launch.png) as this will invoke feh via runcomand.sh.
              #!/bin/bash
              ROMPATH="$3"
              imv-wayland -f -s full -x "$LAUNCHIMAGE" & &>/dev/null
              IMG_PID=$!
              sleep 4
