    8bitdo SN30 pro WIRED directional pad help
    controllerhelp
    6 Posts 3 Posters 892 Views
      cametokur
      I searched and all I can find is information for people asking how to use their dpad as an analog stick. I can't get retro emulators to use the dpad INSTEAD of analog. It worked when I had just a few roms but after transferring a new collection the dpad is not functioning in any nes or snes emulator. Thanks if you can help...
        cametokur @cametokur
        I may have figured this out, but in some emulators, the A button brings up the in game menu! Help?
          G30FF @cametokur
          @cametokur Try to first uninstall and reinstall the xpad driver in RetroPie-Setup, and then remap the controller in ES. The wired-only version of the SN30 Pro is treated as an X-input device, so it behaves like an Xbox 360 controller as far as RetroPie is concerned.
            cametokur @G30FF
            @g30ff Thank you, I'm sorry for the noob posting, but I appreciate your insight.
              G30FF @cametokur
              @cametokur No trouble at all. Hope it helps!
              • theinkT
                theink
                The Xbox controller has been causing me some problems in the past. If your 8bitdo gamepad is set on x-input mode it might act in the same way as a regular Xbox controller.
                I'm not 100% if your issue matches the symptoms I had encountered myself, but consider checking this post. There is a solution at the end that.fixed the problem for me.
                https://retropie.org.uk/forum/topic/26623/ppsspp-mapping-problem-wireless-xbox-controller/14?_=1619570216264
