    Diagnosing ROM problems?
    loading gameserror finding
    23 Posts 6 Posters 6.0k Views
    • ColstarC
      Colstar
      I just wondered if there was a way of finding out why roms fail to load?
      Sometimes I do get a small line of text stating an error, before the Pi returns to the main menu, while over times the screen flashes blue a few times and then back to the main menu without any messages.
      • jamrom2J
        jamrom2 @Colstar
        @colstar speaking in complete general terms because each emulator is different...
        MAME... each revision effects the rom in its own way, some get bits added, others have them removed. So one rom that worked in one version, may not work in another. The correct ROMs versions MUST match to the correct version of MAME.
        Atari800 - it's an emulator that requires a lot of other things to work. One of them being BASIC, and the OSa and OSb depending on the roms requirements. It's not just a plug and go emulator. Takes some time and tweaking.
        Amiga - same as A800. It's not a simple plug and go and does require the games to be built in a certain way.
        A5200 - same as A800 as it uses the same basic emulator to run. Needs some tweaking but once it works, it works really good.
        BIOS files... some require specific BIOS files. You need to read more than just assume putting roms into a folder makes it all work. There is a lot to making systems work, it just takes time and paitence... and reading.
        That's just a few to get started... so you can see where I'm going with this... and this still doesn't account for the crappy ROM dump some games get... so you have to try several versions...etc.
        So to answer your question again... there is no simple answer.
        What exact system are you having issues with?
        ColstarC 1 Reply Last reply Reply Quote 1
        • ColstarC
          Colstar @jamrom2
          @jamrom2 Thanks, that about sums things up I guess. Mostly with MAME games but also ATARI 5200 and from what you have just mentioned they do take a little more work to become playable. 👍
          IanDaemonI 1 Reply Last reply Reply Quote 0
          • IanDaemonI
            IanDaemon @Colstar
            @colstar Can you check the \\retropie\configs\all\emulationstation\es_log.txt /dev/shm/runcommand.log ? Do you have the file after "going back to the main menu"?
            • Cocktail Cabinet Games
            • Check out the MAME RoW
            ColstarC 1 Reply Last reply Reply Quote 0
            • ColstarC
              Colstar @IanDaemon
              @iandaemon Do you mean can I select it and try and load again? Then yes, the screen fades out then flickers blue before going back to the roms list.
              • IanDaemonI
                IanDaemon @Colstar
                @colstar I mean the specific error may be logged in /dev/shm/runcommand.log.
                https://retropie.org.uk/docs/Runcommand/
                S ColstarC 2 Replies Last reply Reply Quote 0
                  sleve_mcdichael @IanDaemon
                  @iandaemon said in Diagnosing ROM problems?:
                  Don't forget to launch with verbose logging enabled for the detailed report.
                  The log file location is not accessible via the network share. To access it more easily, plug a keyboard into the Pi and press F4 to exit EmulationStation, or connect via SSH (Windows has a built-in SSH client; from a command prompt, use ssh pi@retropie.local or, if your network doesn't recognize host names, you can use ssh pi@<your.pi's.ip.address>. The default password, if you haven't changed it previously, is raspberry.) Then copy the file to your roms folder with the command:
                  cp /dev/shm/runcommand.log /home/pi/RetroPie/roms
                  This will put a copy of the log file in your roms folder where it can easily be accessed via the network share.
                  IanDaemonI 1 Reply Last reply Reply Quote 1
                  • ColstarC
                    Colstar @IanDaemon
                    Ah thanks, I have never delved into any of this as yet. May have to take a look!
                    • IanDaemonI
                      IanDaemon @sleve_mcdichael
                      @sleve_mcdichael After I posted and walked away I thought "I should have said something about verbose logging." And for the location...Couldn't you just use a symbolic link to the file?
                      • jamrom2J
                        jamrom2 @Colstar
                        @colstar even without the verbose logging, you'll be able to see where the emulator is failing.
                        As for the MAME roms... you have to match them to the correct version. Which version of MAME did you load?
                        Each version we can run on Retropie correlates to a specific version number of MAME. So they're not the same.
                        As for Atari 5200... it's a bitch to configure... but start with a good BIOS and .a52 roms. They can be zipped, but make sure they are not .atr/.atx roms. Those are for the Atari 800.
                        To setup A5200 and Atari 800 properly.. follow this... we found a problem with the Atari 800 loading script at the end and I think rkoster was going to edit it. If it's not, and it doesn't work... let me know. I helped him with it. I know how to fix it. He did a rock-solid job and everything works better than any other guide I've tried in the past 5 years.
                        https://retropie.org.uk/forum/topic/22392/lr-atari800-5200-artifacting-basic-and-other-guidance/44?_=1619483254571
                        best,
                        Jam
                          (Edit: Yeah, that didn't work. Doesn't work without some additional configuration. See @mitu's post #20 below.)
                          I suppose you could, yeah. Then it would always just "be there" and you wouldn't have to re-copy it every time you needed it. So instead of cp you would use ln -s:
                          ln -s /dev/shm/runcommand.log /home/pi/RetroPie/roms
                          This link will act like a pointer, like a Windows "shortcut," that always points to the most recent version of the log file, instead of a copy which is just a snapshot in time of what the file looked like when you copied it.
                          • jamrom2J
                            jamrom2 @sleve_mcdichael
                            @sleve_mcdichael lol... I was thinking the same thing... you have a really good idea though, so much better than hunting for it every time via WinSCP. With that link you can just open the ROMS folder on your desktop and view it that way.
                            • IanDaemonI
                              IanDaemon @jamrom2
                              I thought of a possible issue. If Windows "can't see" a Linux partition, may the symbolic link be pointed to a location the Windows machine "couldn't see"? (Windows machines aren't the Kwisatz Haderach.)
                              So symbolic links may be A solution, but they definitely are not THE solution.
                                @iandaemon Windows can "see" the roms folder just fine over the network, though. Isn't that already on the Linux partition? That's why we have to use WiFi or a USB stick and can't just add roms directly to the SD card, right?
                                • IanDaemonI
                                  @sleve_mcdichael There are multiple Linux partitions on a RetroPie SD card. The ROMs are just on one that a Windows machine can see. (e.g. accessing over network not ssh) If your Windows computer is on the same network as your Pi you may be able to type \\RETROPIE in Windows Explorer or Internet Explorer and get to the partition that the ROMs are stored via Samba-Shares.
                                  You can see more details here: https://retropie.org.uk/docs/Transferring-Roms/
                                    @iandaemon you're right it doesn't work. I just tried it just now and when I tried to open the file or copy it to another location it failed, and said I needed permission from the system's administrator.
                                    • IanDaemonI
                                      @sleve_mcdichael Did you rename your Pi? I have two so on my Windows laptop I go to \\THINCOCKTAIL and \\GOLDENTEE2005. I believe the login information is by default Raspberry and Pi.
                                      https://retropie.org.uk/docs/Transferring-Roms/#samba-shares
                                      You can't access every file via Samba Shares, but I find it really useful. Is Samba Shares turned on?
                                      jamrom2J S 2 Replies Last reply Reply Quote 0
                                      • jamrom2J
                                        jamrom2 @IanDaemon
                                        @iandaemon opposite... pi is the user, raspberry is the password by default
                                          @iandaemon no, Samba is working fine. I just mean that, as you suggested earlier might be the case, linking the runcommand.log file in the roms directory does in fact not work (no bueno) to make the file always accessible via the network share. I can see that there is a runcommand.log file in the roms folder on the network, but I cannot open it or copy it or move it.
                                            mitu Global Moderator @sleve_mcdichael
                                            @sleve_mcdichael Symlinks are not 'followed' on Samba file shares when they point outside the shared folder, it's a security configuration enabled by default - https://unix.stackexchange.com/questions/5120/how-do-you-make-samba-follow-symlink-outside-the-shared-path.
                                            YFZdudeY 1 Reply Last reply Reply Quote 1
