    Daphne Controls Help
    daphnedaphne joystickdragons lair
    4 Posts 2 Posters 852 Views
      Drdave79
      I'm running Daphne on a Retropi4 arcade cabinet and just cant get the joysticks to recognize. I've edited the dapinput.ini file like a lot of tutorials have suggested, changing the third digit on each line, but still no luck. It works with a keyboard, but no luck with the joysticks. Space Ace, Dragon's Lair I & II. All the same. Hoping someone can post their working dapinput.ini file below to help.
      Thank you!
        tusabez @Drdave79
        @drdave79 Try this https://retropie.org.uk/forum/topic/21063/is-there-a-simple-way-to-make-dragonrise-controllers-work-with-daphne
          Drdave79 @tusabez
          @tusabez Unfortunately that didn't work. Went through all of the steps and still only recognizes keyboard. No joystick or button inputs on any Daphne games.
            Drdave79
            ok, I figured it out. When I read that Daphne uses the first controller it sees, I turned off my guns and it worked just fine.
