    Raspberry Pi Not Working when Adding RetroPie to MicroSD Card
    hdmimicro-sdnot working
    3 Posts 2 Posters 609 Views
    • AtariTacoA
      AtariTaco
      I downloaded Retro Pie and flash drive it to the MicroSD card using an adapter. Then, I put the SD card back into the slot. The Pi is plugged into the wall and is connected via HDMI to my TV. Whenever I change the input to the Pi however, it says "raspberry not found" and then says "no signal".
      dankcushionsD AtariTacoA 2 Replies Last reply Reply Quote 0
        dankcushions Global Moderator @AtariTaco
        @ataritaco please fill out all of https://retropie.org.uk/forum/topic/3/read-this-first
        • AtariTacoA
          AtariTaco @AtariTaco
          Nvm i figured it out
