    Audio Problem: lvl0: VolumeControl::init() - Failed to find mixer elements! - No es_settings.cfg file
    audio outputheadphone
    9 Posts 3 Posters 4.0k Views
    • dsquaredD
      dsquared
      Hello again:
      I have the old lvl0: VolumeControl::init() - Failed to find mixer elements! problem. So apparently, I have to configure emulationstation to switch the audio output from HDMI to Headphone. However, I can't find an es_settings.cfg file to make the change.
      Is there a new place to store this info or do I just create a new es_settings.cfg file with the necessary details?
      Obligatory Information:
      Pi Model or other hardware: 4B+ 8GB
      Power Supply: LABISTS Raspberry Pi 4 Power Supply 5.1V 3A
      RetroPie Version Used: retropie-buster-4.7.12
      Retropie -Setup Script: V4.7.12( used to fix a previous network problem)
      USB Devices connected: Logitech F310 Controller, wireless USB keyboard, PS3 Controller, CREATIVE LABS Pebble Modern 2.0 USB Desktop Speakers (with audio jack)
      Error messages received: lvl0: VolumeControl::init() - Failed to find mixer elements!
      Verbose log: (if relevant): Not Applicable
      Guide used: This Post
      File: config.txt - see attachment 1
      Emulator: Not Applicable
      Attachment 1: config.txt: https://pastebin.com/efqjNY4i
      Thank you in advance
        @dsquared said in Audio Problem: lvl0: VolumeControl::init() - Failed to find mixer elements! - No es_settings.cfg file:
        The configuration can be performed from the EmulationStation's menu, under the Audio settings - choose the 'Audio Device' to one of the desired values (HDMI, Headphone, etc.).
          DarkPaladin @mitu
          @mitu Unfortunately this did not work for me. When I switched 'Audio Device' to Headphone, ES will attempt to launch, generate the "Failed to find mixer elements", and drop back to ES menu.
          Before I changed 'Audio Device', there was no audio at all in ES nor in games (even after starting from a fresh install). But I can at least start the games. As soon as I tried to change the 'Audio Device' to anything, I start getting these errors, and no games will launch anymore. Even if I change 'Audio Device' back to HDMI, I still get the same error.
          Power Supply: Canakit Raspberry Pi 4 Power Supply 5.1V 3A
          RetroPie Version Used: retropie-buster-4.7.1-rpi4_400
          Audio output: normal computer speakers (3.5mm)
          ES Logs:
          Jul 21 20:23:30 lvl2: 	 req sound [basic.launch]
          Jul 21 20:23:30 lvl2: 	   (missing)
          Jul 21 20:23:31 lvl2: 	Attempting to launch game...
          Jul 21 20:23:32 lvl2: 		/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ fba /home/pi/RetroPie/roms/fba/avsp.zip
          Jul 21 20:23:37 lvl2: 	Creating window...
          Jul 21 20:23:37 lvl2: 	Created window successfully.
          Jul 21 20:23:37 lvl2: 	GL vendor:   Broadcom
          Jul 21 20:23:37 lvl2: 	GL renderer: V3D 4.2
          Jul 21 20:23:37 lvl2: 	GL version:  2.1 Mesa 19.3.2
          Jul 21 20:23:37 lvl2: 	Checking available OpenGL extensions...
          Jul 21 20:23:37 lvl2: 	 ARB_texture_non_power_of_two: ok
          Jul 21 20:23:38 lvl2: 	Added known joystick xin-mo.com Xinmotek Controller (instance ID: 12, device index: 0)
          Jul 21 20:23:38 lvl2: 	Added known joystick xin-mo.com Xinmotek Controller (instance ID: 13, device index: 1)
          Jul 21 20:24:02 lvl0: 	VolumeControl::init() - Failed to find mixer elements!
            @darkpaladin said in Audio Problem: lvl0: VolumeControl::init() - Failed to find mixer elements! - No es_settings.cfg file:
            That makes no sense, since the Audio settings in EmulationStation apply to EmulationStation only and have no effect on emulators or launching games.
            Use default as Audio Card and Headphones as Audio Device to get sound from the analog jack on the Pi.
              DarkPaladin @mitu
              @mitu Made no sense to me either.
              Now audio level defaults to 0 no matter what I do. I even plugged something else into the speakers to make sure the speakers did not die on me (they work fine).
              Currently ES is set to "Default/Headphones". Still get "Failed to find mixer elements" and no games will launch. And audio level will revert back to zero as soon as I exit the Sound Settings menu.
                mitu Global Moderator @DarkPaladin
                @darkpaladin Can you post the output of the following commands:
                aplay -L
                amixer
                  DarkPaladin @mitu
                  aplay -L
                  null
                      Discard all samples (playback) or generate zero samples (capture)
                  default:CARD=b1
                      bcm2835 HDMI 1, bcm2835 HDMI 1
                      Default Audio Device
                  sysdefault:CARD=b1
                  dmix:CARD=b1,DEV=0
                      Direct sample mixing device
                  dsnoop:CARD=b1,DEV=0
                      Direct sample snooping device
                  hw:CARD=b1,DEV=0
                      Direct hardware device without any conversions
                  plughw:CARD=b1,DEV=0
                      Hardware device with all software conversions
                  default:CARD=b2
                      bcm2835 HDMI 2, bcm2835 HDMI 2
                  sysdefault:CARD=b2
                  dmix:CARD=b2,DEV=0
                  dsnoop:CARD=b2,DEV=0
                  hw:CARD=b2,DEV=0
                  plughw:CARD=b2,DEV=0
                  default:CARD=Headphones
                      bcm2835 Headphones, bcm2835 Headphones
                  sysdefault:CARD=Headphones
                  dmix:CARD=Headphones,DEV=0
                  dsnoop:CARD=Headphones,DEV=0
                  hw:CARD=Headphones,DEV=0
                  plughw:CARD=Headphones,DEV=0
                  pi@CCCCC-ARCADE:~ $
                  amixer
                  Simple mixer control 'HDMI',0
                    Capabilities: pvolume pvolume-joined pswitch pswitch-joined
                    Playback channels: Mono
                    Limits: Playback -10239 - 400
                    Mono: Playback -4920 [50%] [-49.20dB] [on]
                    @darkpaladin Use the Audio menu in the RetroPie system and switch the audio to 'Headphones', then see if you get the same issue in EmulationStation.
                      DarkPaladin @mitu
                      @mitu Yep, that was it. If I leave the ES audio settings at "Default / HDMI", when I change the Audio in RetroArch to "Headphone", then I can get audio from the 3.5mm port.
                      Very counter-intuitive, but at least it is working now. Thanks for the assist!
