    Problem with GTA:Vice City Stories on PsP.
    vicecitystoriespsp gtagtavc
    39 Posts 13 Posters 10.9k Views
    • windgW
      windg
      Pi Model or other hardware: Pi4
      Power Supply used: Official
      RetroPie Version : 4.7.13
      Built From:RetroPie website
      USB Devices connected: Keyboard, mouse, gamepad
      Controller used: Logitech F310
      Roms from usb stick, 64gb, exFat
      Emulator: lr-ppsspp , ppsspp
      Game have graphic glitch on the beginning and it's unplayable. It was working very well two weeks ago when i check it.
      When the game start, after the intro, the player it's falling from the sky an never ending loop. I test ir-ppsspp and ppsspp with the same results.
      verdose.log: https://pastebin.com/pb71K4rg
      LibationL R 2 Replies Last reply Reply Quote 2
      • George SpiggottG
        George Spiggott
        I'm having the same problem with lr-PPSSPP. I have not checked PPSSPP yet.
        Currently running:
        Retropie 4.8.9 on a Pi Zero 2W (Overclock Settings: CPU 1400Mhz)
        ES-DE on a GMKtec K6 (Windows 11, 32GB RAM)
        • windgW
          windg
          i have this problem after the latest update. I reinstall RetroPie , i build core from source but the result was the same. I have to find a older version of the core to test it.
          • rkhale01R
            rkhale01
            I'm having the exact same issue as well as problems with other games, from what i've read on other forums/comments is that the most recent updates might have messed with PSP emulation, but i just now started trying to get all this working and ran into this so i have no idea whether it was working previously
            George SpiggottG 1 Reply Last reply Reply Quote 0
            • George SpiggottG
              George Spiggott @rkhale01
              @rkhale01 lr-PPSSPP has had problems for me for a while, previous to this it was freezing the graphics. @windg did you manage to find an older version that worked?
              Currently running:
              rkhale01R 1 Reply Last reply Reply Quote 0
              • windgW
                windg
                @george-spiggott
                I try the core from the Lakka, where the game dont have this problem, but the game doesn't start.
                • rkhale01R
                  rkhale01 @George Spiggott
                  @george-spiggott From what I had read,something about PPSSPP emulation got messed up for burnout legends that caused the game to not function well in either LR OR PPSSPP that had worked previously. Do you know if this game worked previous to the last update? I myself am curious if others are getting better results now or in the previous update.
                  • LibationL
                    Libation @windg
                    @windg Same issue here. Works fine on my older image using PPSSPP. As soon as I updated, both GTA VCS and GTA LCS have the same problem, just like what you posted. I've tried updating everything, building from source...no luck. EDIT other PSP games work fine, it's just these two games.
                      Reichling @Libation
                      Same problem here on my Pi4 . There is the really old version of PPSSPP 1.5.4 listed as available on Retropie but it only works on Pi3. I setup my old Pi3 with Retropie and installed PPSSPP 1.5.4 on it. GTA:Vice City Stories works on my Pi3 with 1.5.4 but performance is horrible.
                        Reichling @windg
                        @windg this fixed the problem for me. I installed PPSSPP v1.10.2 and now GTA: Vice City Stories is working again:
                        https://retropie.org.uk/forum/topic/27421/is-there-any-way-to-get-older-emulator-core-binaries/7
                        windgW 1 Reply Last reply Reply Quote 0
                        • windgW
                          windg @Reichling
                          @reichling
                          It doesn't work for me, the compilation end with this error:
                          Error running 'git -C
                          /home/pi/RetroPie-Setup/tmp/build/ppsspp/ppsspp checkout
                          -f 110020000 -b 110020000' returned 128
                          LibationL 1 Reply Last reply Reply Quote 0
                          • LibationL
                            Libation @windg
                            @windg Exact same error I get when trying this fix as well.
                            • windgW
                              windg
                              I report the issue in the github
                              https://github.com/hrydgard/ppsspp/issues/14611
                                death @Reichling
                                @reichling I’ve tried everything to install an older version. Is there anyway you could send me your ppsspp.sh file? Thanks for the help!
                                • windgW
                                  windg
                                  i follow @mitu instructions, on this topic, to downgrade the standalone ppsspp and now the game is working again!
                                    death @windg
                                    @windg this solution doesn't work for me
                                    windgW 1 Reply Last reply Reply Quote 1
                                    • windgW
                                      windg @death
                                      @death I upload the ppsspp script with the change https://easyupload.io/3p44u7 .
                                      N popegg235P 2 Replies Last reply Reply Quote 1
                                      • N
                                        navi87 @windg
                                        @windg
                                        Much appreciated, I noticed this issue about a month ago and I wasnt able to figure how to downgrade, Vice City is working great now.
                                        Would I need to re-apply this ppsspp.sh file if I update the RetroPie scripts when I want to update my emulators??
                                        • windgW
                                          windg @navi87
                                          @navi87
                                          You don't have to re-apply the script.
                                          • George SpiggottG
                                            George Spiggott
                                            Is there a particular place you have to copy the script file to in order to run it?
                                            Currently running:
