    [Retropie] PS4 Controller does not work in Emulators
    ps4controllerbluetoothraspberrypi 3b+retropie 4.7.1
    2 Posts 2 Posters 535 Views
      muto1888
      Hi Guys,
      i am new to RetroPie and trying to get my PS4 Controller working with my RetroPie since 3 evenings. I am sure it's just a simple tweak but I don't get it solved.
      So I installed ds4drv and paired it without problems. It runs just fine in Retropie Menu and I am able to assign keys in retroarch -> Settings -> Input -> Port X Binds, but as soon as a game is started, it does not work. It will however run fine with my keyboard. I do not own other controllers to test with
      Power Supply used: (If using a Pi) Mobile Phone Charger
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.7.1
      Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used) retropie-buster-4.7.1-rpi2_3.img
      USB Devices connected: Keyboard
      Controller used: PS4
      Error messages received: none
      Verbose log (if relevant):
      Emulator: (Name of emulator - if applicable) all
      How to replicate the problem: run any game
      Thanks in advance
      Muto
        The PS4 Dualshock controller should work without any additional driver installation - the ds4drv is an old and un-maintained driver and it shouldn't be used.
        If you configured your controller in EmulationStation, you don't need to do any configuration in RetroArch. The configuration for RetroArch is automatically generated from EmulationStation - see https://retropie.org.uk/docs/Controller-Configuration/. You can check if your auto-configuration for RetroArch has been generated by looking into the \\retropie\configs\all\retroarch-joypads folder (over file shares). Do you have a .cfg file for your controller there ?
        Aside, you should be using a proper power source for your Pi, a mobile phone charger is not enough for most cases, especially on a 3b+. Do you get the low voltage sign when you start a game ?
