    Xbox controller problem
    xbox wired contxbox controllerxbox one s
    11 Posts 2 Posters 2.4k Views
      P3Y0_A15
      Hi everyone. I recently bought a generic wired xbox one controller. I have installed the xpad, xpadneo, and de xboxdrv but still i can configure the controller. The controller is recognized when i start a system which it says xbox one s pad 1118/746 not configured.
      I hope you guys can help me tnx in advance
        For a wired Xbox controller you don't need neither xpadneo nor xboxdrv. Remove the drivers and re-install the xpad driver, then reboot your Pi and configure the controller in EmulationStation.
          P3Y0_A15 @mitu
          @mitu nope i didnt work. While conected to the raspberry the lights keep flashing as if it was searching for playera 1,2,3,4 (and yes i pressed the home button and it didnt work)
            mitu Global Moderator @P3Y0_A15
            @p3y0_a15 Is this a wired or wireless controller ? Wired controllers should connect right away.
              P3Y0_A15 @mitu
              @mitu it's a wired but i can't configure it
                Is the controller working with a PC/Xbox ? Did you try to see if it works on another system but the Pi ?
                  P3Y0_A15 @mitu
                  @mitu Yeah it does Works on PC. I used it on an emulator
                    Add some more info about your setup, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first. In addition to that, run the following command - from the command line - and post the output:
                    cat /proc/bus/input/devices
                      P3Y0_A15 @mitu
                      @mitu ```
                      code_text
                      I: Bus=0003 Vendor=045e Product=02ea Version=0301
                      N: Name="Microsoft X-Box One S pad"
                      P: Phys=usb-0000:01:00.0-1.2/input0
                      S: Sysfs=/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input3
                      U: Uniq=
                      H: Handler=event3 js0
                      B: PROP=0
                      B: EV=20000b
                      B: KEY=7fdb0000 0 0 0 0 0 0 0 0 0
                      B: ABS=3001b
                      B: FF=1 7030000 0 0
                        @p3y0_a15 said in Xbox controller problem:
                        Looks similar to this issue in the xpad driver - it looks like it's not supported properly.
                        Someone made a separate - patched - driver project here, if you want to install it then remove the xpad driver installed by RetroPie and follow the installation instructions from the project page.
                          P3Y0_A15 @mitu
                          @mitu It didnt work. The lights keep flashing as if it was searching for a player (1,2,3,4)
