    Wired SN30 Pro not detected
    sn30 pro
    22 Posts 4 Posters 4.3k Views
      Stuffu
      Hi
      With my Nespi 4 case there are some slight issues with lag. Apparently this is fairly known with the Nespi case, but I like it and can live with having the controllers wired. So I tried connecting the SN30 Pro controllers with USB cable instead. The controllers lights up immediately, but ES doesn't respond to any input from the controller and is not detected as a controller for configuration. Other than lag the controllers works fine with inputs etc.
      I've tried searching for similar issues but haven't found any. Is there anything specific you need to do to use them wired?
      I had a corrupt sd card and had to do a fresh install quite recently so there are not that many changed settings.
      Pi Model or other hardware: RPI 4
      Power Supply used: Original
      RetroPie Version Used 4.7.14
      USB Devices connected: HDD controller
      Controller used: SN30 Pro 1.36
        Is the controller detected by jstest ? Is one of those controllers that you can choose which 'mode' to start ? If yes, then make sure it's started in Xinput or Switch mode, not Android.
          Stuffu @mitu
          @mitu Sorry, forgot to mention that I used Switch mode. It's identified but nothing happens on button press etc. Tried different cables as well.
          pi@retropie:~ $ jstest /dev/input/js0
          Driver version is 2.1.0.
          Joystick (Nintendo Co., Ltd. Pro Controller) has 6 axes (X, Y, Z, Rz, Hat0X, Hat0Y)
          and 18 buttons (Trigger, ThumbBtn, ThumbBtn2, TopBtn, TopBtn2, PinkieBtn, BaseBtn, BaseBtn2, BaseBtn3, BaseBtn4, BaseBtn5, BaseBtn6, ?, ?, ?, BtnDead, (null), (null)).
          Testing ... (interrupt to exit)
          I have two identical controllers and both behave the same way.
            If there's no input, there's not much to do as far as EmulationStation or emulators are concerned. Switch it to PC/XInput mode and see if it starts working.
              Stuffu @mitu
              @mitu It worked! It's recognised as Xbox 360 controller on wired X mode and SN30 Pro Controller wireless. The funny part is that A, B and X is recognised and receive inputs but switch mode Y doesn't trigger anything when wired. But using BT it works fine.
              It might be a placebo effect, but I don't experience the same lag wirelesss with X mode as with Y mode.
              Not really have a need for it myself but if someone else bumps into the same problem it might be good to know that on X mode, the bumpers are recognised but the triggers are not. This applies both to wired and wireless connection.
                mitu Global Moderator @Stuffu
                @stuffu said in Wired SN30 Pro not detected:
                This usually happens when the xpad driver is not installed - the version included in RetroPie will remap the triggers as buttons and they should be recognized. Maybe re-install the driver and then re-configure the gamepad again in EmulationStation.
                  Stuffu @mitu
                  @mitu Guess this ended up in even more questions... I started over and removed es_inputs.cfg removed xpad driver and installed again and configured the controllers again with the same result, no triggers recognised. Also some instances doesn't receive any inputs at all. Like the Retropie-Setup menu. Wired or wireless, keyboard works though.
                    That's not the correct way to re-configure your inputs, removing that file will disable any auto-configuration of the gamepads in the emulators.
                      Stuffu @mitu
                      @mitu Ok, that was bad news. Then I have to make a new install on a separate sd card and copy it from there and start over from there.
                      I'll restore and see what happens. Thanks!
                        Stuffu @mitu
                        @mitu found how to reset es_input.cfg in the documentation but the controllers are still behaving very weird.
                        Even with xpad reinstalled no trigger inputs are recognized and it’s only when wired the controller works outside of ES, like retropie setup menu.
                        In scummvm the controller only works as mouse input when wired and I can’t launch any games when controller is wireless since no controller is detected, even if the controller is set up and is working in the frontend.
                        I understand that this is a pain, should I just give up using the controller wired as well as wireless and go back to wireless only, or could there be an “easy” solution to try?
                          The RetroPie-Setup menu uses the RetroArch configuration for the gamepad, which is generated automatically by EmulationStation when the input is configured (barring a broken es_input.cfg). Is the controller working correctly in any of the libretro emulators ?
                          I'm not sure how ScummVM uses the gamepad, it's one of the emulators that's not auto-configured by EmulationStation.
                            Stuffu @mitu
                            @mitu I restored es_input.cfg so everything is fine there.
                            None of the libretro emulators work, when launching a game, a black screen appears and then quits back to the emulator. Nothing odd in runcommand.log but it's for sure related the controller settings.
                            When wired, the controller is identified as Xbox 360 controller and libretro works. When wireless the controller is identified as SN30 Pro and no libretro emulators work.
                            Just to clarify, this was also the behaviour prior to removing es_input.cfg
                            As I mentioned earlier, if this is something only affecting me, it's not that important and I know you have better things to do instead of troubleshooting this :) I can go back to Switch mode and just sit very close to the RPI :)
                              Shouldn't be, since RetroArch can work even without a controller. If you get a verbose log, post it on pastebin.com
                              Does RetroArch pops up a notification saying that the controller is detected, but not configured ? If so, the auto-configuration file is missing - that's created automatically by EmulationStation after the input configuration. You can check in /opt/retropie/configs/all/retroarch-joypads and see what configuration files are there, there should one for each controller type (name) you have configured in EmulationStation.
                                Stuffu @mitu
                                @mitu In the verbose log there is something odd. https://pastebin.com/6ZzDcBwC
                                [INFO] [CONTENT LOAD]: Loading content file: /home/pi/RetroPie/roms/nes/Super Mario Bros. (JU) (PRG0) [!].zip#__MACOSX/._Super Mario Bros. (JU) (PRG0) [!].nes
                                [ERROR] [CONTENT LOAD]: Could not read content file "/home/pi/RetroPie/roms/nes/Super Mario Bros. (JU) (PRG0) [!].zip#__MACOSX/._Super Mario Bros. (JU) (PRG0) [!].nes".
                                I don't see any reference to macosx somewhere in any file but this doesn't seem to have anything to do with the controller... Seems there are two different problem that at first seemed related but aren't...
                                There is no RetroArch popup saying it's not configured. I noticed the names of the different inputs when configuring wired/wireless.
                                Also, there are both 8Bitdo SN30 Pro.cfg and Microsoft X-Box 360 pad.cfgin retroarch-joypads
                                  Yes, it's unrelated. The .zip file contains a __MACOSX folder, usually added by the Finder in macOS to store additional data about files and RetroArch tries to load the first file from the archive, which happens to be ._Super Mario Bros. (JU) (PRG0) [!].nes. You should either unzip the archive and use the .nes ROM or clean up the .zip file(s).
                                  Related to the gamepad not working in RetroPie setup, a similar thing happened to me because of the same Finder behavior. Editing/opening a gamepad .cfg in the macos Finder would create a similar file in /opt/retropie/configs/all/retroarch-joypads (._8Bitdo SN30 Pro.cfg), which would be picked by the joy2key (the utility that translates the gamepad inputs to keyboard keys and thus enabled navigation of the setup scripts with the gamepad) and would render the gamepad navigation unusable. Check for any ._XYZ.cfg files in /opt/retropie/configs/all/retroarch-joypads and remove them - you'll need to use Linux for that, since the Finder won't show them.
                                    Stuffu @mitu
                                    Oh no, this is a disaster... But I don't really get it. The .zip files did work before and are untouched and unzipping them (also showing hidden files) just shows the .nes file, nothing else. Could it be something else? (fingers crossed)
                                    I will look into that as well.
                                    Thanks for the suggestions and help here, invaluable as always! :)
                                      G30FF @Stuffu
                                      @stuffu As someone who also owns this controller (well, SN30 Pro+) and tend to use it wired, I tend to use it in D-input/Android mode (Start+B). It works just fine for me, with all buttons working correctly. It uses the same mapping as when it's connected via Bluetooth in this mode.
                                      As someone who also uses a Mac, I have encountered this problem before. Zipping files with the right click -> Compress action in Finder will zip up hidden files like __MACOSX. Unzipping a file created in this way on MacOS will not show the hidden __MACOSX folder. I had a bunch of files created like this (romhacks mostly) that stopped working after a recent RetroPie update with all OS packages. I assume it's an update for Retroarch that caused it to no longer work. Fortunately, you can clean up your zip files created like this by opening Terminal and running the following command:
                                      zip -d "FILE.zip" __MACOSX/\*
                                      That will delete the __MACOSX folder and all contents from the specified ZIP file. Zipping files using the "zip" command on the command line will avoid zipping hidden files like __MACOSX or .DS_STORE in the first place. You could also create a shortcut in Automator that will let you compress files without hidden metadata files from the right click menu.
                                        Stuffu @G30FF
                                        @g30ff Thanks for responding and for the suggestion! I suspected that something changed recently that made this problem occur. Will try out the Start+B option as well as the zip files. However, I have a lot of zip files! :) Can you apply it to all .zip files in a specific folder?
                                          G30FF @Stuffu
                                          @stuffu I have tons of zip files as well, so I wrote myself a shell script to do it for multiple folders. If you know how to use shell scripts, take this script, and save it as a .sh file. I've used it myself, but run at your own risk.
                                          #!/bin/bash
                                          for d in ./*/ ; do
                                          	cd "$d"
                                          	for zipFile in *.zip; do
                                          		echo "Cleaning up ${zipFile}..."
                                          		zip -d "${zipFile}" __MACOSX/\*
                                          		echo "Done"
                                          	done
                                          	cd ../
                                          done
                                          echo "All done."
                                          Assuming your rom folder is organized, for example, /roms/nes, /roms/snes, /roms/megadrive, etc., you would place the shell script in /roms, and then run it. The script will check all subfolders of the current directory for zip files and run the cleanup command on them, if they have __MACOSX folders contained in them.
                                          S 1 Reply Last reply Reply Quote 2
                                          • ClassicGMRC
                                            ClassicGMR
                                            This probably won't add anything to the conversation but here's what happened to me today - sounds almost the same.
                                            My older SN30 controllers were connecting via Bluetooth and in Emulation Station they would work fine. All buttons did what they were supposed to. When I tried to play a game with them the D-Pad worked BUT ABXY weren't even registering and for some reason START was acting like B. Turns out my controllers were on 3.00 Firmware. I updated them to 4.20 (looks like the SN30 Pro latest firmware is v1.34), deleted the Bluetooth entry, rebooted and then paired them again using the 8BitDo guide. Now they work exactly as they should. It was just a firmware issue for me. I didn't see it mentioned in the thread so just putting in my 2 cents. :)
                                            Good luck!
                                            Growing older is mandatory. Growing up is optional!
                                            Enjoy the ride!
