    Help residualvm grim fandango not working fully
    residualvmscummvmgrim fandango
    5 Posts 2 Posters 830 Views
    • L
      luckyluca
      Hi,
      I'm having two issues running Grim Fandango:
      -Grim Fandango starts from the residualvm start menu.
      However it does not start from ES saying 'game data not found'.
      Other residual games such as the longest journey start from ES just fine.
      -When launching from the residualvm start menu, the save option is not there. So I can't save.
      Any ideas?
      using residual 0.4 git
      retropie 4.71
      pi400
      many thanks!
      • L
        luckyluca @luckyluca
        @luckyluca
        solved, but not sure why.
        Save is not accessible unless pressing f1 on the keyboard.
        Is there any chance to map f1 to the controller somehow?
        Best
        L
        • retropieuser555R
          retropieuser555 @luckyluca
          @luckyluca I've only played grim fandango on scummvm as it now supports it but doesn't it have save in the scummvm/residualvm menu itself?
          Pi 5 4GB
          • L
            luckyluca @retropieuser555
            @retropieuser555
            exactly, the save option is missing.
            Did you just update scummvm or need to change git branch to get the new scummvm version?
            thanks
            • retropieuser555R
              @luckyluca I think when you update from source with scummvm now you get the latest version
              Pi 5 4GB
