    My 8bitdo sn30pro+ connected in Switch mode, will not work with the Redream emulator
    redream8bitdosn30prosn30pro+switch
    2 Posts 2 Posters 699 Views
    • vic-viper-001V
      vic-viper-001
      I use an 8bitdo SN30Pro+ in Switch (pro controller) mode, and have had zero problems... until now.
      Whenever I try to use the Redream Emulator it does not see my controller, so I can't map the buttons or play any games. If I connect this same controller in "X or D-input" mode, then I CAN map the buttons and play a game. The problem is, I already use these two pairing modes for other devices.
      I could swear I've used my Switch mode-connected SN30Pro+ with Redream in the past, and was able to map the buttons just fine. Am I wrong or just remembering incorrectly? Has Redream now or in the past, ever supported controllers that connect using Switch mode?
      Is it possible to get an 8bitdo SN30pro+ in "Switch mode" to work with Redream?
      Pi 4
      CanaKit 3.5A Pi 4 Power Supply
      RetroPie Version: 4.7.1
      Built From: retropie-buster-4.7.1-rpi4_400.img.gz
      USB Devices connected: mini keyboard
      Controller used: 8bitdo sn30pro+
      Emulator: Redream
      Config File: redream.cfg (https://paste.ubuntu.com/p/yrCfz72Mph/)
      I've tried...
      -uninstalling and reinstalling Redream multiple times
      -updating Redream
      -updating controller firmware
      -deleting redream.cfg
        geese howard
        This post is deleted!
