    Strange issue with DosBOX control config
    dosbox mapdosbox configdosbox
    2 Posts 2 Posters 402 Views
      Codafire
      Hi, i was configuring my MSDOS games giving independent .cfg and .map files for everyone. I have an issue in common with all, i map the ESC to Select gamepad button and the ENTER to Start button, all works perfectly but when i exit and enter again.... The remap its saved correctly, and correctly asigned but when i push select or start game dont recognice it so i dont have ESC and ENTER, until i enter again, remaps it again and all works fine. Its only appening to me with ESC and ENTER not with other inputs. Any ideas??? 🧐🧐🧐
      • jamrom2J
        jamrom2 @Codafire
        @codafire
        Hi. You kinda skipped a few steps in describing the issue. What emulator are you using. What version of Retropie? RetroArch? There are 4 emulator options for Dos and each is slightly different version from each other. So that's really important.
        Also... Are you saving the config to the same file or renaming it to a new one? How are you doing this in the emulator? Do you know how to look at the files of RetroPie? If so, what does the .map file say?
