    Retropie x86 on GalliumOS - Baytrail audio issues
    chromebookgalliumosretropie x86baytrail
    4 Posts 2 Posters 895 Views
    • g2000G
      g2000
      Hello everyone,
      I've been playing around with some old Chromebooks that we are decommissioning and figured what a great machine to do some emulation. Had some great success with Braswell chipsets and it worked great. I am trying this out on a Baytrail chipset (HP CB G3) and audio during emulation is very choppy/garbled. Tried several things I came across the forum here and others regarding pulseaudio but noting seems to resolve it (making changes to the default.pa file, restarting services, adjusting frequencies, making changes to alsa & pulseaudio etc).
      I tried some of the suggestions posted here but did not resolve the issue:
      https://retropie.org.uk/forum/topic/22119/audio-lag-retropie-x86/2
      What I did find is that as soon as the machine was plugged into and HDMI port, audio played back normal on the internal chrombook speakers. As soon as the HDMI source changed, sound reverted back to gabled on the internal speakers. On other my other working chromebook config looks like this:
      <string name="AudioCard" value="default" />
      <string name="AudioDevice" value="Master" />
      <string name="OMXAudioDev" value="both" />
      I played around with some of the audio OMXAudioDev settings and didnt have much luck either. Has anyone else come across this issue? Any ideas or suggestions? Thanks in advance.
      • johnodonJ
        johnodon
        Run xrandr to make sure you are not running at a low refresh rate (i.e. 30hz). Choppy audio is usually a symptom.
        # xrandr
        Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
        DVI-D-0 disconnected primary (normal left inverted right x axis y axis)
        HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 1440mm x 810mm
           3840x2160     30.00 +  59.94    29.97    23.98    23.98
           4096x2160     59.94    29.97    24.00    23.98
           1920x1080     60.00*   59.94    29.97    23.98
           1680x1050     59.95
           1440x900      59.89
           1360x768      60.02
           1280x1024     75.02    60.02
           1280x960      60.00
           1280x800      59.81
           1280x720      60.00    59.94    29.97    23.98
           1152x864      75.00
           1024x768      75.03    70.07    60.00
           800x600       75.00    72.19    60.32
           720x480       59.94
           640x480       75.00    72.81    59.94    59.93
        g2000G 1 Reply Last reply Reply Quote 1
        • g2000G
          g2000 @johnodon
          @johnodon - THAT DID IT!!! Omg dude thank you! I've been loosing my mind with this. So it ends up there are two resolutions this thing picks up. It defaults to 1366x768 that has two refresh rates 60Hz and 40Hz. The next one is 1360x768 and runs at 60 - 59Hz. Switched it to that and magically it just worked. Cant believe it was something that simple. Canτ thank you enough!
          johnodonJ 1 Reply Last reply Reply Quote 0
          • johnodonJ
            johnodon @g2000
            @g2000 said in Retropie x86 on GalliumOS - Baytrail audio issues:
            Been there. :D More often than not, 4K TVs are the culprit.
