    Audio configuration with RetroPie and PIXEL on the same RPI4
    audiopulseaudiopixel
    5 Posts 2 Posters 643 Views
    • mochapieM
      mochapie
      Pi Model or other hardware: Raspberry Pi 4 Model B Rev 1.2
      Power Supply used: 3.5A
      RetroPie Version Used: 4.7.15
      Built From: RetroPie 4.7.1 (RPI 4/400) image via Raspberry Pi Imager v1.6.1
      I'm running into a pesky audio issue when having both RetroPie and PIXEL desktop installed on the same RPI4. After reading through this thread, I'm able to get audio in emulationstation by uninstalling puslseaudio on my system. At the same time, I'm also interested in having the PIXEL desktop installed in order to compile and play other non-RetroPie games (e.g., GTA3). However, it seems that PIXEL installations require pulseaudio to output audio (which I uninstalled in order to output audio in emulationstation).
      For now, I created entries in my RetroPie Ports menu to install and remove pulseaudio whenever I feel like switching game modes, but it's not the most ideal scenario. I'm also not sure if this is the best place to post this issue, but I thought I'd give it a shot to see if anyone has any tips.
      Is there any way to have pulseaudio installed and still output audio in emulationstation?
        mitu Global Moderator @mochapie
        @mochapie said in Audio configuration with RetroPie and PIXEL on the same RPI4:
        Try to choose default as the AudioCard and MASTER/PCM as AudioDevice in EmulationStation's Audio configuration.
        mochapieM 1 Reply Last reply Reply Quote 0
        • mochapieM
          mochapie @mitu
          @mitu Well... that worked! But now I'm getting the message 1v10: VolumeControl::init() - Failed to attach default card!. Is there any way to peacefully get rid of this?
            That seems to indicate that the default option for the card is not working. Can you use the Audio menu in the RetroPie system and reset the audio settings, then see if you still get the message ?
            • mochapieM
              mochapie @mitu
              @mitu that seems to have done the trick, thanks for your help.
