    need help with installed script
    scriptsystems.cfg
    5 Posts 3 Posters 580 Views
    • O
      OfficialAzyria
      Can someone help me with this? I’m using the Parker_Hemphill custom system generator. But I always get this. When I tell it to do the reboot, it doesn’t add the system? alt text
      this is the script that i'm using. i'm doing everything it tells me but i'm getting permission denied. i really don't want to add 20 more systems by hand because i don't really want to and i don't have the time https://www.reddit.com/r/RetroPie/comments/eulhnh/custom_es_systemscfg_generator_script/
        Looks like the permissions on the some files/folders are incorrect.
        How did you install RetroPie ? Did you use the image from retropie.org.uk/download or a third party image ?
        What's the source of script that you're trying to run ? (Peter_Hemphill script is not something that I'm familiar with).
        Thorr69T O 2 Replies Last reply Reply Quote 0
        • Thorr69T
          Thorr69 @mitu
          @officialazyria said in need help with installed script:
          @mitu said in need help with installed script:
          What's the source of script that you're trying to run ? (_Peter_Hemphill script_ is not something that I'm familiar with).
          Got a little Spiderman on the brain @mitu ? ;-)
          There's a link to the script he used right at the end of his post.
          RPi 3b
          Official PSU
          Official RetroPie image
          Pandora's Box 5 controller
          • O
            OfficialAzyria @mitu
            @mitu i used the experimentalpi (piboy) image, which only fixes a few things so it works on a small screen
              mitu Global Moderator @OfficialAzyria
              @officialazyria We don't support 3rd party images and your issue is most likely caused by bad permissions on your .emulationstation folder.
              @Thorr69 I partially blind these days, thanks for the heads up.
