    Controller problems with moonlight
    moonlightgamaepad
    2 Posts 1 Posters 633 Views
      phialek
      Pi 4 4gb
      Power Supply: apple macbookpro m1 power supply
      RetroPie Version: 4.7.16
      USB Devices connected: 2 x arcade sticks with 16 buttons (8 for each player) (dragon rise controller), 2 usb keboard
      Bluetooth devices: 2 x ipega gamepad
      I used moonlight a lot in my raspberry pi 4 arcade cabinet with arcade sticks and buttons (dragon rise controller). Everything worked perfectly. But since a couple of days my dragon rise arcade sticks don't work properly, maybe it had to do with an update I did.
      Everything is still mapped right (mapping wasnt necessary), but now the arcade stick controls the left and right triggers as well. I have the joystick working as the left analog stick, but now it sends left and right triggers as well. When i turn the joystick to the left, there are no trigger signals, when its in the middle then its sending half triggers signals (like analog half pressed), when turned to the right it sends full trigger signals.
      I have tried everything. Deinstalled and cleaned moonlight, updated it, reinstalled it. I have even made custom mapping which was a pain because i couldn't skip buttons.
      Nothing solves this problem. By the way i have 2 ipega controller connected as well wich work normally also steam link behaves normally as well.
      Is there anything i can do?
      Thank you.
        phialek @phialek
        I have opened an issue at github and they solved the problem. It was an issue in a mapping file. Update is online and it fixwa the problem.
