    Help manually adding boxart using Emulation Station Metadata feature
    box artmetadata
    3 Posts 2 Posters 2.5k Views
      RaptorBandito
      Pi Model or other hardware: Pi4B 4gb ram
      Power Supply used: Vilros Pi 4 Power Supply
      RetroPie Version Used: 4.7.11
      USB Devices connected:32gb flash drive, 2 USB gamepads
      Controller used: Vilros gamepad, Switch Pro Controller
      Error messages received: n/a
      Verbose log (if relevant): n/a
      Guide used: n/a
      I recently bought a copy of the Xenocrisis rom and I'm trying to add some custom box art, marquees, and cart images using the Emulation Station Metadata feature. I put them in a custom folder named "art" under the Genesis roms folder. So I believe the path should be /home/pi/retropie/roms/genesis/art/xenocrisis.png as an example. It doesn't seem to work, so I'm assuming something in my folder paths is incorrect. Can anyone confirm what the correct path would be?
      roslofR 1 Reply Last reply Reply Quote 0
      • roslofR
        roslof @RaptorBandito
        @raptorbandito said in Help manually adding boxart using Emulation Station Metadata feature:
        In Unix, capitalization matters. "RetroPie" is the correct folder name. Try:
        /home/pi/RetroPie/roms/genesis/art/xenocrisis.png
        Also ensure that the filename and extension are also capitalized correctly. Hope that solves it for you.
          RaptorBandito @roslof
          @roslof
          That did the trick! Thank you. I guess since I looked at the folder path in windows explorer, and it spelled "RetroPie" in lower case as "retropie" I assumed that would be the correct folder name. Thanks for you help!
