    Anyone know why lr-fmsx doesn't work on Pi 4?
    fmsxmsxlr-fmsx
    27 Posts 2 Posters 4.8k Views
      JimmyFromTheBay @Folly
      @folly said in Anyone know why lr-fmsx doesn't work on Pi 4?:
      I altered the .dsk with openmsx.
      You have to eject the disk on boot and later insert it again when you are in basic.
      That way you can see the files on disk with the command files.
      Then you have to load JETSET.BAS with load"jetset.bas".
      Do list or in this case you can do list 0.
      Alter the POKE -1,170 into POKE -1,(15-PEEK(-1)\16)*17 .
      Then save the file again with save"jetset.bas"
      If you want to you can run with run and you will execute the basic file.
      Now the .dsk file is changed and you will be able to load it into the other emulators.
      I tried Astro Blaster with nms8250. I was able to eject the disk, access BASIC and insert the disk again. There was only one .BAS file on there, which had a single line of code which didn't mention any POKEs. I typed the POKE in directly anyway and typed RUN, but it just continually rebooted itself like it did before.
      • FollyF
        Folly @JimmyFromTheBay
        @jimmyfromthebay
        I had a look at Astro Blaster.
        It doesn't work for me too, It has a different issue, that I can't find.
        But basically the disk is probably a conversion of a ROM.
        So you should find a ROM and use that.
        I have a rom version and it loads.
        Search the internet for "file-hunter"
        With these commands you should be able to find all the "Astro Blaster" files :
        cd /home/pi/RetroPie/roms/msx
        find -name "Astro Bl*"
        • FollyF
          @jimmyfromthebay
          Edit: patch is added here :
          https://github.com/FollyMaddy/RetroPie-Share/tree/main/00-roms-00/msx/Astro Blaster (1988)(Eurosoft)
          I found the issues.
          The Astro Blaster (1988)(Eurosoft)-changed.dsk has a poke issue and with40 issue.
          I have this file :
          Command to get the md5sum of the file :
          md5sum "Astro Blaster (1988)(Eurosoft).dsk"
          Output of the md5sum command :
          6a65f8df7b188c4cc5d1c52a3b63a46e  Astro Blaster (1988)(Eurosoft).dsk
          This is the edit to fix it :
          (from)
          (to)
            @jimmyfromthebay
            I found the issues.
            You're a wizard :D
            Flips recognised the patch this time, all working :)
            • FollyF
              @jimmyfromthebay
              Aha, MAGIC, that's nice to hear !
              Btw., what is the md5sum of your "Jet Set Willy (1984)(Software Projects).dsk" ?
              Perhaps you have a different file than me, if so, the patch probably will not work because of that.
              It would be nice to know the cause.
                JimmyFromTheBay
                @jimmyfromthebay
                I suspect the cause was GitHub. I can never remember which method of downloading files from GitHub pages gets you the real file, and which way gets you a broken useless one just pretending to be it.
                • FollyF
                  @jimmyfromthebay said in Anyone know why lr-fmsx doesn't work on Pi 4?:
                  @jimmyfromthebay
                  Never mind.
