    Two 8BitDo SN30 pro controllers using bluetooth
    controller
    3 Posts 2 Posters 808 Views
      MastaG
      Hi there,
      I have two SN30 pro controllers connected to my Pi4 using bluetooth but they're giving me some issues.
      If I connect them using X-Input (start + X) mode, the triggers don't registeren.
      This is a known problem, but I worked around this, by adding them to the configuration manually.
      The only problem which remains is the fact that RetroArch always takes up 30 seconds to start now :(
      So I removed the controllers and re-paired them in Switch mode (start + Y).
      They now show up as Pro Controllers and I have no such issues mapping the triggers.
      However now the rumble/vibration function doesn't work.
      Is there any bluetooth mode which supports rumble/vibration but doesn't add the annoying delay when starting RetroArch??
      ClassicGMRC 1 Reply Last reply Reply Quote 0
      • ClassicGMRC
        ClassicGMR @MastaG
        @mastag May or may not help but check that the controllers are on the current firmware. Mine were old and I was having a lot of connection trouble. Can't hurt to verify. :)
        https://support.8bitdo.com/firmware-updater.html
        Growing older is mandatory. Growing up is optional!
        Enjoy the ride!
          MastaG
          They were on the latest update.
          I already figured it out for myself.
          I've uninstalled the xpad and xpadneo drivers from the RetroPie setup utility.
          Then I installed the latest neoxpad driver from github, with this patch applied: https://patch-diff.githubusercontent.com/raw/atar-axis/xpadneo/pull/283.patch
          Finally I edited the /etc/modprobe.d/99-neoxpad-bluetooth.conf file, comment out the disable ertm thing and make sure to load it with xpad emulation enabled:
          # options bluetooth disable_ertm=y
          options hid_neoxpad xpad_emulation=1
          Reboot and pair both controllers in xpad mode.
          Setup both controllers in emulationstation and skip the non-working left and right triggers.
          When done simply close emulationstation and add the triggers manually:
          input_r2_axis = "+5"
          input_l2_axis = "+2"
          Et voila!
          Both controllers working in x-input mode, without the shitty startup delay when launching retroarch and working rumble for my psx and dreamcast games.
