    LCD Problem with driver
    lcddriverraspberry pi 0w3.5 inch screen
    2 Posts 1 Posters 447 Views
    • E
      Elisium9999
      Hi,
      I am trying to configure a 3.5 inch lcd on a raspberry pi 0w, I am following this guide and I can't get it to work (actually the image provided by this page works fine in my lcd), but if i try to configure the driver on retropie image it doesn't work.
      • E
        Elisium9999
        Post Update:
        With this command I can display without problem "image-test.gif" in this case, I think the problem is something in the retropie configuration that I can't see
        pi@raspberrypi ~ $ sudo apt-get install fbi
        pi@raspberrypi ~ $ wget https://ozzmaker.com/piscreen/image-test.gif
        pi@raspberrypi ~ $ sudo fbi -noverbose -T 1 -a -d /dev/fb1 image-test.gif
        (/boot/config.txt)
