    How does MSX & ColecoVision Co-Exist in BlueMSX?
    bluemsxcolecovisionmsx
    35 Posts 6 Posters 5.7k Views
    • TPRT
      TPR
      Every time I make a change in BlueMSX options running an MSX rom to tell it to use the MSX emulator, let's just say "auto" for this example, it makes that same change to ColecoVision. When I open a ColecoVision ROM, it thinks I'm trying to run an MSX game and I have to change the system type back to "ColecoVision." Then if I go run an MSX rom, I have to change it back.
      Do I need to make a game options file for EVERY SINGLE COLECOVISION game???
      or is there a better way? Thank you.
      FollyF Lister of SmegL 2 Replies Last reply Reply Quote 0
      • FollyF
        Folly @TPR
        @tpr
        If both systems are correctly installed then...
        the /opt/retropie/configs/all/retroarch-core-options.cfg contains :
        bluemsx_msxtype = "Auto"
        The coleco system type is embedded in this config :
        /opt/retropie/configs/coleco/retroarch-core-options.cfg containing :
        bluemsx_msxtype = "ColecoVision"
        So you have to place your msx games in :
        /home/pi/RetroPie/roms/msx/
        And
        Your coleco games in :
        /home/pi/RetroPie/roms/coleco
        Then It should work OOB.
        When you edit the system, I think you will be changing this file :
        But for msx you should add it in here, I think :
        /opt/retropie/configs/msx/retroarch-core-options.cfg
        Make sure you don't already have game specific .opt files in here:
        /opt/retropie/configs/all/retroarch/config/blueMSX
        so the don't overrule the other core-option files.
        TPRT S 2 Replies Last reply Reply Quote 0
        • TPRT
          TPR @Folly
          @folly So this is how it would appear I have everything configured. But no matter what I seem to do, if I open a ColecoVision game, it opens as MSX, and if I go into the options and change the system to ColecoVision, it creates a blueMSX.opt file in /opt/retropie/configs/all/retroarch/config/blueMSX
          I do have a retroarch-core-options.cfg in my /opt/retropie/configs/coleco folder and config is below, but for whatever reason it does not seem to be reading this. Even if I delete the blueMSX.opt file it just creates a new one. Not sure why it's functioning like this.
          bluemsx_auto_rewind_cas = "ON"
          bluemsx_cartmapper = "Auto"
          bluemsx_nospritelimits = "ON"
          bluemsx_overscan = "disabled"
          bluemsx_vdp_synctype = "Auto"
          bluemsx_ym2413_enable = "enabled"
          EDIT:
          The retroarch-core-options.cfg file in my /opt/retropie/configs/all contains this for bluemsx:
          So I can't figure out why when I load a CV game it is overriding the .cfg file in the /coleco folder and instead loading the config above.
          • FollyF
            Folly @TPR
            @tpr
            My BlueMSX.opt looks like this :
            bluemsx_nospritelimits = "OFF"
            Did you load your game with the verbose option and checked the /dev/runcommand.log ?
            Perhaps you can find a clue in there.
            TPRT 2 Replies Last reply Reply Quote 0
            • TPRT
              TPR @Folly
              @folly yeah, the only difference between yours and mine is that I just prefer to turn off the sprite flickering. I can load it with verbose logging and see if that has any other clues.
              As I'm typing this, I had just completely removed BlueMSX and re-installed from binary and I'm still getting the same issues.
              • FollyF
                Folly @TPR
                @tpr
                Basically your emulators config line loads a system specific retroarch.cfg.
                Take coleco then it will load :
                /opt/retropie/configs/coleco/retroarch.cfg
                Above file redirects to :
                core_options_path = "/opt/retropie/configs/coleco/retroarch-core-options.cfg"
                That way it should load the coleco system.
                TPRT 1 Reply Last reply Reply Quote 0
                • TPRT
                  TPR @Folly
                  @folly So here's the verbose runcommand log:
                  https://www.dropbox.com/s/6ka7oshhxwbi4ec/runcommand_msx.log?dl=0
                  I can see at the end it says this:
                  [INFO] [Core Options]: Saved core options file to "/home/pi/.config/retroarch/config/blueMSX/blueMSX.opt"
                  But I have no idea why it keeps trying to load that file. If I delete that file, it automatically loads as MSX and when I exit out, it just makes another one. I cannot seem to figure out why it's sharing that .opt file between both consoles.
                  • TPRT
                    TPR @Folly
                    @folly In my /opt/retropie/configs/coleco here is the retroarch.cfg:
                    #Settings made here will only override settings in the global retroarch.cfg if placed above the #include line
                    input_remapping_directory = "/opt/retropie/configs/coleco/"
                    quit_press_twice = "false"
                    and my retroarch-core-options.cfg in /opt/retropie/configs/coleco
                    I cannot figure out why it keeps loading as an MSX machine.
                    • TPRT
                      TPR @TPR
                      The only way I can see to get around this right now is to make an .opt file for every single ColecoVision ROM I have that specifically calls out the system type as ColecoVision.
                      • FollyF
                        Folly @TPR
                        @tpr
                        I checked mine and your log.
                        mine does this instead :
                        [INFO] [Core Options]: Saved core options file to "/opt/retropie/configs/coleco/retroarch-core-options.cfg"
                        • TPRT
                          TPR @Folly
                          @folly Yes, this is what is contained in that .cfg file in that folder:
                          • FollyF
                            Folly @TPR
                            @tpr
                            Indeed, very strange.
                            Don't have a solution right now.
                            • TPRT
                              TPR @Folly
                              @folly Just for fun I removed that "press_quit_twice" thing and I'm still getting this in my runcommand log:
                              I can't figure it out either. I don't think I've ever run into an issue like this before.
                              • TPRT
                                TPR @Folly
                                @folly Thanks for at least looking into it. I think at this point I'm just going to make a separate game options file for every single ColecoVision ROM. That's the only fix I can think of at the moment that will at least get this working.
                                FollyF D 2 Replies Last reply Reply Quote 0
                                • FollyF
                                  Folly @TPR
                                  @tpr
                                  Yes, that is the only option for now.
                                  Perhaps someone else has an idea how to fix this.
                                    dmmarti @TPR
                                    @tpr Do you have a file in this folder?
                                    [INFO] [Remaps]: core-specific remap found at /opt/retropie/configs/coleco/blueMSX/blueMSX.rmp.
                                    saw that in your verbose log.
                                    If so, delete it and see if that fixes it.
                                    TPRT 3 Replies Last reply Reply Quote 0
                                    • TPRT
                                      TPR @dmmarti
                                      @dmmarti Let me go look...
                                      • TPRT
                                        TPR @dmmarti
                                        @dmmarti Damn... I do. Let me rename that now and see if it helps.
                                        • FollyF
                                          Folly @TPR
                                          @tpr
                                          Indeed my log doesn't refer to a remap file.
                                          • TPRT
                                            TPR @dmmarti
                                            @dmmarti Nope. Didn't fix it. It also removed the ColecoVision specific remap for controls I had made. So I don't think that's the culprit.
