    need help on retropie
    retropie help
    4 Posts 2 Posters 443 Views
      John66
      I have a raspiberry pi4 I just install retropie4 and the only problem i have is that I went in the retropie setup to install the commodore64 emulator vice with a problem error and try binary and source and will not install vice and I can not update retropie setup script all so as there may be a problem with retropie software. Can any one help
        dankcushions Global Moderator @John66
        @john66 please fill out https://retropie.org.uk/forum/topic/3/read-this-first - please also show us the errors via a screenshot or a copy/paste via SSH
          John66
          here are some picture of the new Retropie for the rasberry pi4 as I fill the Retropie has some bug!20210824_084154.jpg 20210824_084145.jpg 20210824_084112.jpg 20210824_084100.jpg
            John66 @John66
            I just gave up on Retropie 4 it so bad I can not do any update it just keep on trying to do update with Error so i am format the sd card and no longer installing Retropie again.
