    No sound - GPi Case - Failed to attached default card
    audio issueno sound
    8 Posts 3 Posters 3.6k Views
      gts197
      Hello,
      I did some searching and did find posts that had no sound issues etc but I was unable to find anything that matched exactly what I am dealing with and alot of the fixes require access to the "Audio" menu that I cannot even get access to. Attached are images of the error I am getting when I try to adjust the settings in the "Audio" menu. I am unable to get any sound working on my Retro Pi install in my GPi Case. Any help would be greatly appreciated. I am trying to avoid needing to reinstall everything.
      Screen Shot 2021-09-07 at 8.40.24 AM.jpg Screen Shot 2021-09-07 at 8.40.32 AM.jpg
        Please add some info about your setup as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        How is the GPI case outputting sound ? Does it use an I2S hat ? Judging by the 1st message from the screenshot (from the Audio settings), looks like the onboard sound is disabled via config.txt.
          gts197 @mitu
          @mitu Thanks for the reply. See below information:
          Pi Model or other hardware: (PI 0 W)
          Power Supply used: (n/a)
          RetroPie Version Used (4.7.18):
          Built From: (retropie-buster-4.7.1-rpi1_zero)
          USB Devices connected: (IO conversion board included with GPi Case - https://www.retroflag.com/GPi-CASE.html)
          With regards to the config file I never edited it. I am unable to get access to it at the moment but I could upload if needed.
            Looking at the support site, it doesn't look like it's going to work OOB with the RetroPie image - the video needs configuring and it looks like there's some configuration added for the audio also. Are you sure you're using the stock RetroPie image ? Post your config.txt.
              gts197 @mitu
              @mitu All the patches that are required for the case were installed. The only thing that is not working is the audio.
              I am 100% sure that the image used was downloaded directly from the official site for the Pi 0.
              Below is the text of the config file. It would not allow me to upload the actual file.
              # http://www.raspberrypi.org/documentation/configuration/config-txt.md
              #hdmi_safe=1
              #disable_overscan=1
              #overscan_left=16
              #overscan_right=16
              #overscan_top=16
              #overscan_bottom=16
              # overscan.
              #framebuffer_width=1280
              #framebuffer_height=720
              #hdmi_force_hotplug=1
              #hdmi_group=1
              #hdmi_mode=1
              #hdmi_drive=2
              #hdmi_force_edid_audio=1
              # no display
              #config_hdmi_boost=4
              # uncomment for composite PAL
              #sdtv_mode=2
              #arm_freq=800
              #dtparam=i2c_arm=on
              #dtparam=i2s=on
              #dtparam=spi=on
              # Uncomment this to enable the lirc-rpi module
              #dtoverlay=lirc-rpi
              dtparam=audio=on
              #config_hdmi_boost=0
              # force hdmi while the tv can take time before sending the signal on the hdmi output
              #sdtv_mode=2
              # uncomment for lirc-rpi
              #dtoverlay=lirc-rpi
              # if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
              boot_delay=3
              # uncomment if you don't want the rainbow at startup
              disable_splash=1
              # default CEC name
              cec_osd_name=recalbox
              # Overclock
              gpu_mem_256=128
              gpu_mem_512=256
              gpu_mem_1024=512
              avoid_safe_mode=1
              kernel=zImage
              #dtparam=audio=on
              display_rotate=1
              dtoverlay=dpi24
              overscan_left=0
              overscan_right=0
              overscan_top=0
              overscan_bottom=0
              framebuffer_width=320
              framebuffer_height=240
              enable_dpi_lcd=1
              display_default_lcd=1
              dpi_group=2
              dpi_mode=87
              dpi_output_format=0x6016
              #hdmi_timings=320 0 28 18 28 480 0 2 2 4 0 0 0 60 0 32000000 6
              hdmi_timings=240 1 38 10 20 320 1 20 4 4 0 0 0 60 0 6400000 1
              dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
              disable_pvt=1
              disable_audio_dither=1
              dtoverlay=pwm-audio-pi-zero
                gts197
                @mitu So I did some digging and found a post here talking about this and I was able to get sound going in games only…doesn’t seem to be working in the menus but thats ok.
                Here is a link to that post (https://retropie.org.uk/forum/topic/28809/no-in-game-sound-after-the-dec-2020-raspberry-pi-os-updates/6)
                I added this to the first line in /boot/cmdline.txt and it did the trick.
                snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_compat_alsa=1
                  mitu Global Moderator @gts197
                  @gts197 Glad you got it sorted.
                  RetroFlag should update their scripts to work with newer Raspberry Pi OS releases or at least have some more details explanations on how the sound works with their overlay.
                  2Play2 1 Reply Last reply Reply Quote 0
                  • 2Play2
                    2Play @mitu
                    @mitu I agree with you.
                    I was experimenting recently on pi0 and checked the RetroFlag "patch" for their GPi Case and it has by default disabled#dtparam=audio=on applied to the config .txt which causes the exact error posted
                    If the # is removed and reboot the sound is back to normal.
                    They should update their scripts/info rather users get troubles and need to apply cmdline alsa or edit sudo nano /usr/share/alsa/alsa.confand change
                    defaults.ctl.card 0
                    defaults.pcm.card 0
                    to
                    defaults.ctl.card 1
                    defaults.pcm.card 1
                    Your friend,
                    2Play!
