    Occasional picture issues with Megadrives Roms
    raspberrypi4bmegadriveroms not workin
    7 Posts 3 Posters 787 Views
    • hawkes_84H
      hawkes_84
      Hi all
      Model: pi4 b
      Retropie 4.7.18
      Power Supply: suitable
      So I'm experiencing some problems with megadrive roms when I select one only a quarter of the image will appear on the screen and the rest of it is just black screen. When I restart ES or shutdown and on again that particular rom will
      be fine and a different one will have the problem. As far as I can tell it's only doing it for megadrive roms. Could this be a PSU issue?
        sleve_mcdichael
        And it cuts off the on-screen messages, like this?: https://imgur.com/ARWb83Y
        I think it's a known issue. I just reset with hotkey+B a couple of times until it rights itself.
        hawkes_84H 1 Reply Last reply Reply Quote 0
        • hawkes_84H
          hawkes_84 @sleve_mcdichael
          @sleve_mcdichael Yep exactly like this. I had a feeling it was a known issue but a difficult one to search for. Yes I've just learnt I can reset to normal again. Was there an actual fix for it?
            sleve_mcdichael @hawkes_84
            @hawkes_84 said in Occasional picture issues with Megadrives Roms:
            I don't think so, or if there is it hasn't been integrated into the RetroPie fork yet. You could try a different emulator.
            hawkes_84H 1 Reply Last reply Reply Quote 1
            • hawkes_84H
              @sleve_mcdichael No problem. Thanks for the info
              YFZdudeY 1 Reply Last reply Reply Quote 0
              • YFZdudeY
                YFZdude @hawkes_84
                @hawkes_84
                This has been around for a bit. Here are a couple of threads on it.
                https://retropie.org.uk/forum/topic/27933/3-quarter-black-screen/3
                https://retropie.org.uk/forum/topic/26322/pi-4-display-issue-with-lr-genesis-plus-gx/12
                The hotkey reset can fix it many times but you will likely have to do it each time you launch a game.
                Or you can try disabling widgets as instructed further down in the second link.
                • hawkes_84H
                  hawkes_84 @YFZdude
                  @yfzdude cheers dude. Helpful stuff
