    Raspberry Pi OS: shortcut for RetroPie does not start games
    shortcutraspbiandesktopretropie 4.7
    5 Posts 2 Posters 750 Views
    • L
      Lilian3004
      Device: Raspberry Pi 4B
      Power supply: original power supply
      Guide used: none
      Im currently trying to create a shortcut for RetroPie on Raspberry Pi OS.
      My thought was to create an entry for the start menu and then putting that entry on the desktop.
      I started the Main Menu editor and made a new entry in the Games section.
      Preferences/Main Menu Editor
      I used the following path for the emulationstation script: (emulationstation.sh)
      /bin/emulationstation.sh
      The shortcut loads the emulationstation interface and with it the installed games but it does not start the games. Instead i get redirected to the game list.
      So: am i using the right path, right script etc? I have a feeling he only starts the interface but not the emulators.
      Would it even work with this way?
        dankcushions Global Moderator @Lilian3004
        @lilian3004 launching retropie within the desktop is not supported. you should log out and launch via commandline, or boot into retropie directly as per https://retropie.org.uk/docs/FAQ/#where-did-the-desktop-go
        • L
          Lilian3004 @dankcushions
          @dankcushions oh i see, i thought it would work somehow. Good to know!
          Then i have a different question. Is there a Steam Link plugin in the RetroPie distribution?
            @lilian3004 apparently :) https://retropie.org.uk/forum/topic/28294/steam-link-within-retropie
            • L
              @dankcushions oh cool, then i will try that out. thanks a lot for your help!
