    Using Gamepads and Arcade Controls At the same time.
    gamepadcontrols
    8 Posts 5 Posters 2.7k Views
      jxkx18
      Hi all this may be a little hard to explain. I have a cocktail cabinet with a pi 3b+ in it. I want to use gamepads for the system emulators sometimes but I want the arcade controls to be default. Is there any way to quickly switch to a gamepad and then back to arcade controls if I need to??
      • AddisonA
        Addison
        To create a custom profile for a single console...
        Open a game using the target console emulator
        Hold the Select button and press X
        Choose Controls
        Optimize your button configuration as needed
        Choose Save Core Remap File
        To create a custom profile for a single game...
        Open the game you want to create a custom controller profile for
        Choose Controls
        Choose Save Game Remap File
        Hope this helps. :)
        • DigrizD
          Digriz
          Hi,
          I have a 2x USB splitters on 1 on Port 1 & 1 on Port 2, I use a zero delay plugged into Port 1 with a 8bitdo controller and the same for port 2.
          I downloaded Joystick selector https://github.com/meleu/RetroPie-joystick-selection
          Configured all my controllers to use the using the zero delays (aka joystick/arcade buttons) as the default.
          Then configured my Dreamcast/PSP/PSX/N64 games to use only the 8bitdo controllers.
          Best of both worlds, have analog when it's needed for dreamcast etc and standard arcade controls for MAME/FBN etc.
          Happy to contribute.
          Raspberry Pi 4 o/c to 2MHz
          Pizen Case & Ice Tower
          Samsung T5 External SSD (500GB)
          Official Pi4 Power Supply
          RetroPie 4.7.1 image built with Raspberry Pi Imager on 512Gb SanDisk Extreme Pro microSDXC card
          2x DragonRise Controllers
          2x 8BitDo SN30Pro+
          DigrizD 1 Reply Last reply Reply Quote 1
            jxkx18
            Thanks guys I will work with those ideas. I was just wondering what if I wanted to switch back to arcade controls quick for lets say snes.
            • DigrizD
              Digriz @Digriz
              @digriz said in Using Gamepads and Arcade Controls At the same time.:
              Hi,
              Configured all my emulators to use the using the zero delays (aka joystick/arcade buttons) as the default.
              Happy to contribute. quick edit.
              You could configure SNES to use both arcade and/or controller
              2x 8BitDo SN30Pro+
                jxkx18
                Ok I deleted to config file for snes and now both arcade and gamepad work at the same time. Thanks a lot for the quick responses.
                • F
                  Flopsi
                  Hello i cant install RetroPie-joystick-selection
                  Waht can i do ??
                  Thanks for Help.
                    mitu Global Moderator @Flopsi
                    @flopsi said in Using Gamepads and Arcade Controls At the same time.:
                    Waht can i do ??
                    As the printed error hints - do you have the RetroPie-Setup folder in /home/pi ? How did you install RetroPie ? Please add more info about your setup, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
