    3-way volume switch Arcade1up / Pi3B+
    arcade1upconfig.inivolume control
    5 Posts 2 Posters 619 Views
    • E
      ezra84
      Hi,
      I have an Arcade1Up Street Fighter II CE cabinet with a Pi3b+ installed and I'm trying to make the original 3-way volume switch to work.
      I've found a couple of tutorials but they are all meant for use with RetroPie whilst I'm using a pre-made Recallbox image.
      I did wire the switch to the pi already, but I suppose I should add some script to make it work.
      Does anyone know where and how to do this?
      Thanks!
        mitu Global Moderator @ezra84
        @ezra84 This is a RetroPie forum, not the Recalbox support forum - it's not the same software. Also, links to sites with copyrighted material are not allowed in the forum, please remove the link to the site.
        I'd advise you to try the Recalbox forums, but - just as here - they're not going to support a 3rd party image.
        E 2 Replies Last reply Reply Quote 0
        • E
          ezra84 @mitu
          @mitu ok sorry about this, I'll remove it.
          • E
            ezra84 @mitu
            @mitu I can edit but not delete the post. I keep seeing the 3 minutes after posting error even though it's longer ago.
              @ezra84 Not sure what error are you seeing. You should have deleted just the site from where you downloaded the image, not the rest. The post is ok now.
