    Issue running F12000 with Duckstation
    13 Posts 3 Posters 1.3k Views
    • I
      isidoro80
      Hello i have install lr-duckstation but i can't play with F12000. In runcommand.log i read: pal bios not found. I have all ps1 bios .bin in folder bios and folder roms/ps1. I play f12000 with dusckstation desktop version in pixel desktop but i don't play in lr-duckstation. Can you help me? Thanks
        dankcushions Global Moderator @isidoro80
        @isidoro80 please provide the full info and verbose logs as per https://retropie.org.uk/forum/topic/3/read-this-first
        • mituM mitu moved this topic from Ideas and Development on
          I've split the post into a separate topic, the announcement topic for Duckstation shouldn't be used for all questions and problems related to the new emulator.
          I 1 Reply Last reply Reply Quote 1
          • I
            isidoro80 @mitu
            @mitu 34 / 5000
            where should I post my problem?
              mitu Global Moderator @isidoro80
              Here, in this new topic. Provide the info asked by @dankcushions - the verbose log file should especially be useful.
              • I
                isidoro80 @mitu
                @mitu hello i post runcommand.log i have pi4 4 gb ram retropie 4.7 and last version of retroarch.
                i can play f12000 with desktop version of duckstation but i can not play f12000 with lr-duckstation
                Parameters:
                Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-duckstation/duckstation_libretro.so </dev/null --config /opt/retropie/configs/psx/retroarch.cfg "/home/pi/RetroPie/roms/psx/F12000/F1 2000 (Italy).cue" --verbose --appendconfig /dev/shm/retroarch.cfg
                [INFO] RetroArch 1.9.7 (Git 8373ac6)
                [INFO] Funzionalità:  NEON VFPv3 VFPv4
                [INFO] Built: Sep 15 2021
                [INFO] Version: 1.9.7
                [INFO] Git: 8373ac6
                [INFO] [Input]: Found input driver: "x".
                [INFO] [Core]: Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-duckstation/duckstation_libretro.so"
                [INFO] [Overrides]: No core-specific overrides found at "/home/pi/.config/retroarch/config/DuckStation/DuckStation.cfg".
                [INFO] [Overrides]: No content-dir-specific overrides found at "/home/pi/.config/retroarch/config/DuckStation/F12000.cfg".
                [INFO] [Overrides]: No game-specific overrides found at "/home/pi/.config/retroarch/config/DuckStation/F1 2000 (Italy).cfg".
                [INFO] [Environ]: GET_CORE_OPTIONS_VERSION.
                [INFO] [Environ]: SET_CORE_OPTIONS.
                [INFO] [Environ]: UNSUPPORTED (#69).
                [INFO] [Environ]: GET_DISK_CONTROL_INTERFACE_VERSION.
                [INFO] [Environ]: SET_DISK_CONTROL_EXT_INTERFACE.
                [INFO] [Environ]: GET_LOG_INTERFACE.
                [INFO] [Remaps]: Remap directory: "/home/pi/.config/retroarch/config/remaps".
                [INFO] [Overrides]: Reindirizzare il file di salvataggio su "/home/pi/RetroPie/roms/psx/F12000/F1 2000 (Italy).srm".
                [INFO] [Overrides]: Reindirizzare il salva stato su "/home/pi/RetroPie/roms/psx/F12000/F1 2000 (Italy).state".
                [INFO] [Environ]: GET_RUMBLE_INTERFACE.
                [libretro INFO] [LibretroHostInterface] Port 1 = DigitalController
                [libretro INFO] [LibretroHostInterface] Port 2 = None
                [libretro INFO] [LibretroHostInterface] Port 3 = None
                [libretro INFO] [LibretroHostInterface] Port 4 = None
                [libretro INFO] [LibretroHostInterface] Port 5 = None
                [libretro INFO] [LibretroHostInterface] Port 6 = None
                [libretro INFO] [LibretroHostInterface] Port 7 = None
                [libretro INFO] [LibretroHostInterface] Port 8 = None
                [INFO] [Environ]: GET_SAVE_DIRECTORY.
                [INFO] [Environ]: SET_CONTROLLER_INFO.
                [INFO] [Environ]: SET_INPUT_DESCRIPTORS:
                [INFO] [CONTENT LOAD]: Il caricamento del contenuto è stato saltato. Le Implemenzioni verranno caricati in proprio.
                [libretro INFO] [Main] retro_load_game(/home/pi/RetroPie/roms/psx/F12000/F1 2000 (Italy).cue)
                [libretro INFO] [HostInterface] Boot Filename: /home/pi/RetroPie/roms/psx/F12000/F1 2000 (Italy).cue
                [INFO] [Environ]: SET_PIXEL_FORMAT: RGB565.
                [libretro INFO] [HostInterface] Creating 'Cubeb' audio stream, sample rate = 44100, channels = 2, buffer size = 2048
                [libretro INFO] [System] Loading CD image '/home/pi/RetroPie/roms/psx/F12000/F1 2000 (Italy).cue'...
                [libretro INFO] [CDSubChannelReplacement] Loaded 32 replacement sectors from '/home/pi/RetroPie/roms/psx/F12000/F1 2000 (Italy).sbi'
                [libretro INFO] [System] Auto-detected console PAL region for '/home/pi/RetroPie/roms/psx/F12000/F1 2000 (Italy).cue' (region PAL)
                [libretro INFO] [System] Console Region: PAL (Europe, Australia)
                [WARN] [Environ]: SYSTEM DIR is empty, assume CONTENT DIR /home/pi/RetroPie/roms/psx/F12000/F1 2000 (Italy).cue
                [INFO] [Environ]: SYSTEM_DIRECTORY: "".
                [libretro INFO] [HostInterface] Searching for a PAL (Europe, Australia) BIOS in '/home/pi/RetroPie/roms/psx/F12000/'...
                [libretro WARN] [FindBIOSImageInDirectory] Skipping 'F1 2000 (Italy) (Track 1).bin': incorrect size
                [libretro WARN] [FindBIOSImageInDirectory] Skipping 'F1 2000 (Italy) (Track 1).sbi': incorrect size
                [libretro WARN] [FindBIOSImageInDirectory] Skipping 'F1 2000 (Italy) (Track 2).bin': incorrect size
                [libretro WARN] [FindBIOSImageInDirectory] Skipping 'F1 2000 (Italy).cue': incorrect size
                [libretro WARN] [FindBIOSImageInDirectory] Skipping 'F1 2000 (Italy).sbi': incorrect size
                [libretro WARN] [FindBIOSImageInDirectory] Skipping 'F1 2000 (Italy).srm': incorrect size
                [libretro WARN] [FindBIOSImageInDirectory] Skipping 'pcsx-card2.mcd': incorrect size
                [INFO] [Environ]: SET_MESSAGE: ERROR: No BIOS image found for PAL (Europe, Australia) region
                [libretro ERROR] [ReportError] No BIOS image found for PAL (Europe, Australia) region
                [INFO] [Environ]: SET_MESSAGE: ERROR: Failed to load PAL BIOS.
                [libretro ERROR] [ReportError] Failed to load PAL BIOS.
                [libretro INFO] [LibretroHostInterface] Running game changed:  (/)
                [INFO] [Environ]: SET_MESSAGE: ERROR: System failed to boot. The log may contain more information.
                [libretro ERROR] [ReportError] System failed to boot. The log may contain more information.
                [ERROR] [CONTENT LOAD]: Impossibile caricare il contenuto
                [INFO] [Core]: Content ran for a total of: 00 hours, 00 minutes, 00 seconds.
                [INFO] [Core]: Unloading core..
                [INFO] [Core]: Unloading core symbols..
                [INFO] [Core Options]: Saved core options file to "/home/pi/.config/retroarch/config/DuckStation/DuckStation.opt"
                [INFO] [Video]: Does not have enough samples for monitor refresh rate estimation. Requires to run for at least 4096 frames.
                  @isidoro80
                  this means you have a non-default /opt/retropie/configs/all/retroarch.cfg and/or /opt/retropie/configs/psx/retroarch.cfg. please upload them.
                  • I
                    isidoro80 @dankcushions
                    @dankcushions said in Issue running F12000 with Duckstation:
                    link to my file in my drive
                      @isidoro80 because you have reset your RetroArch's configuration, the emulator cannot find the needed BIOS files. As @dankcushions said, the SYSTEM_DIRECTORY is not set, so if your PS1 BIOS files are in the recommended place (the BIOS folder), they'll not be found.
                      Rename both config files, then re-install retroarch and then the lr-duckstation packages from RetroPie-Setup, this will generate the default (for RetroPie) configuration files with proper paths and settings.
                      If you want to change a configuration option for a specific core or game, save a core/game Override - don't use 'Save Configuration'.
                      • I
                        isidoro80 @mitu
                        @mitu I have never restored a configuration. maybe I might have saved a configuration. if the problem is the retroarch file just delete it and retroarch generates it from scratch. I'll give it a try and let you know. so the best solution to save the configuration changes is to use the save core / game override option? thank you very much
                          @isidoro80 said in Issue running F12000 with Duckstation:
                          No, don't do that. Re-install the packages I mentioned, immediately after you delete/rename the file(s), otherwise RetroArch will generate a default conf that will not work properly.
                          I 2 Replies Last reply Reply Quote 1
                          • I
                            isidoro80 @mitu
                            @mitu ok thanks
                            • I
                              isidoro80 @mitu
                              @mitu fantastic now lr-duckstation work thank you very much i am very happy
