    reset button problem
    @retroarch
    4 Posts 2 Posters 394 Views
      kounabi22
      i have change the reset button from retroarch hotkey menu from 2 to "+2" but it still keep the "2" button together with the "+2" button.
      Currently running Retropie 4.7.19 on a Pi 4B 2GB
      Overclock Settings: CPU 2000, GPU 600.
        +2 is not a valid button number. Post the exact configuration you have and what exactly are you trying to do.
          kounabi22 @mitu
          @mitu said in reset button problem:
          for the joypad i want input_reset_btn = "+2"
            kounabi22 @kounabi22
            @kounabi22
            ok found solution i change it.
