    problem with error log /dev/tty1: Permission denied
    @emulastation
    18 Posts 3 Posters 1.9k Views
      kounabi22
      Sometimes when pi4 is boot into the menu and im gona roll to choose a game it freeze in video preview
      i check the log file and i see this error
      Oct 17 01:32:56 retropie mtp-probe: checking bus 1, device 12: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2.2"
      Oct 17 01:32:56 retropie mtp-probe: bus: 1, device: 12 was not an MTP device
      Oct 17 01:32:58 retropie mtp-probe: checking bus 1, device 13: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2.1"
      Oct 17 01:32:58 retropie mtp-probe: bus: 1, device: 13 was not an MTP device
      Oct 17 01:33:03 retropie dialog: *** err
      Oct 17 01:33:03 retropie dialog: /dev/tty1: Permission denied
      Oct 17 01:33:03 retropie dialog: Oh, oh, it's an error! possibly I die!
      Currently running Retropie 4.7.19 on a Pi 4B 2GB
      Overclock Settings: CPU 2000, GPU 600.
        The errors in the log don't give any indication of why the freeze happens.
        What video player do you have configured in EmulationStation ? Did you change it from the default ? Do you get the freeze if you remove your overclock ?
          kounabi22 @mitu
          i have try omx and still sometimes it freeze , before i update kernel there where no freeze, did not try to remove overclock because some games will run slow i dont want that.
            How did you update the kernel ? Removing the overclock can be done just for testing, to confirm if there's an issue with the recent kernel.
              kounabi22 @mitu
              from here
              24827321-5d16-4989-a0a6-9c9afc18287b-εικόνα.png image url)
              after that i notice that sometimes when i leave the screensaver after a random time it freeze,or when i go to the menu of the list games and i roll down ,when it try to load the video preview it freeze and here is random.
              i try with no sound, with omx enable or disable, play with the vram to 80 or 100 or 120, every time in some random time it freeze.
                mitu Global Moderator @kounabi22
                @kounabi22 The update procedure is ok.
                Looking at the menu screen, the version of RetroPie that is reported doesn't seem aligned with your signature. RetroPie version 4.3.8 doesn't even support the Pi4. How did you install RetroPie ?
                K 2 Replies Last reply Reply Quote 0
                  kounabi22 @mitu
                  this pic is from the internet i just use to to see how i update it.
                  i have lower the overclock to 2.000 from 2200 but still the freeze happend at random.
                  i will try to remove it and see if it happend again because of overclock.
                    Clyde @kounabi22
                    @kounabi22 Rule of thumb: Always disable tweaks like overclocking when diagnosing problems, as they are the usual suspects.
                    Regarding screenshots, there's a command line tool called raspi2png. See here about how to install and use it. You'll need an ssh connection to the Pi, though.
                      kounabi22 @mitu
                      i have somehow fix the freeze but now there is no sound in screesaver videos and video previews ,if i switch to omx player then sound is back on both problems but video resolution is not correct.
                        @kounabi22 How exactly did you fix the issue ?
                        As for the sound problem, what are your audio settings in EmulationStation - what device/card did you set there ?
                          kounabi22 @mitu
                          @mitu said in problem with error log /dev/tty1: Permission denied:
                          in emulastation i have hdmi and in rasbperry menu i have choose again hdmi still only omx player give sound, in the games i have no problem.
                            Post a screenshot of your ES Audio settings. You didn't specified how you fixed your other issue, that might affect your config and cause your current problem.
                            ClydeC K 2 Replies Last reply Reply Quote 0
                              Clyde @mitu
                              And even if it doesn't, the solution might help others with a similar problem. 👍
                                kounabi22 @mitu
                                i fix it by change the theme to carbon.
                                ClydeC mituM 2 Replies Last reply Reply Quote 0
                                  Clyde @kounabi22
                                  @kounabi22 said in problem with error log /dev/tty1: Permission denied:
                                  From which one? (that might've caused the problem, so it may be good to check it for errors.)
                                    kounabi22 @Clyde
                                    @clyde said in problem with error log /dev/tty1: Permission denied:
                                    it was retrowave and retrowave 4/3
                                      That's just a workaround, you probably have too little memory allocated to the GPU - either in config.txt or in EmulationStation (or both).
                                      As for the audio settings, you should probably have change:
                                      • Audio card should be set to 'Default'
                                      • Audio device should be set to 'HDMI'
                                      • OMX Player Audio device should be fine as it is, or you can set it to Alsa.
                                        kounabi22 @mitu
                                        i try audio card default but i get no sound with audio device "hdmi" only "master" option works.
                                        omx player alsa is fine.
