    No sound retroflag gpi case with pi zero w 2 (Solved)
    retroflag gpipi zero w 2 pla
    53 Posts 14 Posters 16.1k Views
    • retropieuser555R
      retropieuser555
      Oct 29 15:50:11 lvl0: 	VolumeControl::init() - Failed to attach to default card!
      ALSA lib confmisc.c:767:(parse_card) cannot find card '0'
      ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
      ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
      ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
      ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
      ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
      ALSA lib conf.c:5047:(snd_config_expand) Evaluate error: No such file or directory
      ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM default
      Oct 29 15:50:13 lvl0: 	AudioManager Error - Unable to open SDL audio: ALSA: Couldn't open audio device: No such file or directory
      Just following from the other topic thread.
      So I've got the pi w 2 working with the pi2-3 weekly build.
      I changed the config using the retroflag patch and added in the audio and dpi24 dts overlays. But am now getting the above errors and no audio. However video works perfectly.
      Anyone got any ideas? It's not to do with pulseaudio is it? As I just checked that's not installed
      Pi 5 4GB
        tonyrh
        I'm no expert but I think support is needed for the new firmware released by the Raspberry Pi Foundation for the Zero 2 W (https://github.com/raspberrypi/firmware/blob/master/boot/bcm2710-rpi-zero-2.dtb).
          mitu Global Moderator @retropieuser555
          @retropieuser555 said in No sound retroflag gpi case with pi zero w 2:
          Is the sound working without the patches from RetroFlag ? Post your config.txt.
          • retropieuser555R
            retropieuser555 @mitu
            @mitu here's the config for the patch:-
            # http://www.raspberrypi.org/documentation/configuration/config-txt.md
            #hdmi_safe=1
            #disable_overscan=1
            #overscan_left=16
            #overscan_right=16
            #overscan_top=16
            #overscan_bottom=16
            # overscan.
            #framebuffer_width=1280
            #framebuffer_height=720
            #hdmi_force_hotplug=1
            #hdmi_group=1
            #hdmi_mode=1
            #hdmi_drive=2
            # no display
            #config_hdmi_boost=4
            # uncomment for composite PAL
            #sdtv_mode=2
            #arm_freq=800
            #dtparam=i2c_arm=on
            #dtparam=i2s=on
            #dtparam=spi=on
            # Uncomment this to enable the lirc-rpi module
            #dtoverlay=lirc-rpi
            dtparam=audio=on
            #config_hdmi_boost=0
            # force hdmi while the tv can take time before sending the signal on the hdmi output
            #sdtv_mode=2
            # uncomment for lirc-rpi
            #dtoverlay=lirc-rpi
            # if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
            boot_delay=3
            # uncomment if you don't want the rainbow at startup
            disable_splash=1
            # default CEC name
            cec_osd_name=recalbox
            # Overclock
            gpu_mem_256=128
            gpu_mem_512=256
            gpu_mem_1024=512
            avoid_safe_mode=1
            kernel=zImage
            #dtparam=audio=on
            display_rotate=1
            dtoverlay=dpi24
            overscan_left=0
            overscan_right=0
            overscan_top=0
            overscan_bottom=0
            framebuffer_width=320
            framebuffer_height=240
            enable_dpi_lcd=1
            display_default_lcd=1
            dpi_group=2
            dpi_mode=87
            dpi_output_format=0x6016
            #hdmi_timings=320 0 28 18 28 480 0 2 2 4 0 0 0 60 0 32000000 6
            hdmi_timings=240 1 38 10 20 320 1 20 4 4 0 0 0 60 0 6400000 1
            dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
            disable_pvt=1
            disable_audio_dither=1
            dtoverlay=pwm-audio-pi-zero
            I've just tested with the regular stock config file that comes with the weekly retropie 2-3 image. Obviously doesn't give any video or audio as the pi isn't connected by hdmi but through the gpio pins. But ssh into the pi is giving me the same audio error as above.
            Pi 5 4GB
              What's the output of:
              aplay -l
              amixer
              I see in the config that the on-board audio is not disabled, but the audio is also configured over the GPIO pins with the pwm-2chan and pwm-audio-pi-zero overlays, which might not work 100% on the new model.
              • retropieuser555R
                @mitu We get:-
                aplay: device_list:272: no soundcards found...
                Pi 5 4GB
                • PhilcommP
                  Philcomm
                  I spent a good amount of time now on trying to figure out what is the problem. I don't think it's the overlays, since when you use a video splash screen, it gives out sound. It's probable that the splashscreen package uses pulseaudio while everything RetroArch related doesn't.
                  mituM retropieuser555R 2 Replies Last reply Reply Quote 1
                    mitu Global Moderator @Philcomm
                    @philcomm said in No sound retroflag gpi case with pi zero w 2:
                    No, it's not the splashscreen. The errors come from ES, which is not related to the splashscreen at all.
                      Do you have an $HOME/.asoundrc or /etc/asound.confg file ?
                      • retropieuser555R
                        retropieuser555 @Philcomm
                        @philcomm okay that's interesting, I didn't notice that. I just tested a splashscreen with audio and it did play the sound for me too, no errors.
                        I tested out the beta of the recalbox image they have and it played audio as well, so it does seem workable somehow, there config file is quite different though, I always thought the config.txt is universal to the raspberry pi itself, rather than the OS etc?
                        Pi 5 4GB
                        PhilcommP 1 Reply Last reply Reply Quote 0
                        • retropieuser555R
                          @mitu the files aren't there. I guess need to install something?
                          pi@retropie:~ $ cd ..
                          pi@retropie:/home $ ls
                          pi
                          pi@retropie:/home $ cd /etc
                          pi@retropie:/etc $ ls
                          adduser.conf            group            modprobe.d        rpc
                          alternatives            group-           modules           rpi-issue
                          apparmor.d              gshadow          modules.bak       rsyslog.conf
                          apt                     gshadow-         modules-load.d    rsyslog.d
                          avahi                   gss              motd              samba
                          bash.bashrc             host.conf        mtab              securetty
                          bash_completion         hostname         nanorc            security
                          bash_completion.d       hosts            netconfig         selinux
                          bindresvport.blacklist  hosts.allow      network           sensors3.conf
                          binfmt.d                hosts.deny       networks          sensors.d
                          bluetooth               idmapd.conf      nsswitch.conf     services
                          ca-certificates         ifplugd          openal            shadow
                          ca-certificates.conf    init             opt               shadow-
                          calendar                init.d           os-release        shells
                          cifs-utils              initramfs-tools  pam.conf          skel
                          console-setup           inputrc          pam.d             splashscreen.list
                          cowpoke.conf            insserv          passwd            ssh
                          cron.d                  insserv.conf     passwd-           ssl
                          cron.daily              insserv.conf.d   paxctld.conf      subgid
                          cron.hourly             iproute2         perl              subuid
                          cron.monthly            issue            pmount.allow      subversion
                          crontab                 issue.net        polkit-1          sudoers
                          cron.weekly             kernel           ppp               sudoers.d
                          dbus-1                  ldap             profile           sysctl.conf
                          debconf.conf            ld.so.cache      profile.d         sysctl.d
                          debian_version          ld.so.conf       protocols         systemd
                          default                 ld.so.conf.d     pulse             terminfo
                          deluser.conf            ld.so.preload    python            timezone
                          devscripts.conf         libaudit.conf    python2.7         tmpfiles.d
                          dhcp                    libnl-3          python3           triggerhappy
                          dhcpcd.conf             locale.alias     python3.7         ucf.conf
                          dkms                    locale.gen       rc0.d             udev
                          dphys-swapfile          localtime        rc1.d             ufw
                          dpkg                    logcheck         rc2.d             update-motd.d
                          emacs                   login.defs       rc3.d             usb_modeswitch.conf
                          emulationstation        logrotate.conf   rc4.d             usb_modeswitch.d
                          environment             logrotate.d      rc5.d             usbmount
                          fake-hwclock.data       machine-id       rc6.d             vdpau_wrapper.cfg
                          fb.modes                magic            rc.local          vim
                          fonts                   magic.mime       rcS.d             vulkan
                          fstab                   mailcap          request-key.conf  wgetrc
                          fuse.conf               mailcap.order    request-key.d     wpa_supplicant
                          gai.conf                manpath.config   resolv.conf       X11
                          gdb                     mc               resolv.conf.bak   xattr.conf
                          glvnd                   mime.types       resolvconf.conf   xdg
                          groff                   mke2fs.conf      rmt
                          Pi 5 4GB
                            @retropieuser555 Is this before adding the RetroFlag's drivers/scripts or after ?
                            Normally, on a clean install, none of the files are present. Since aplay doesn't list any sound cards, the error you get in ES is normal, but I'm wondering if the GPIO connection on the RetroFlag case don't need additional configuration.
                            The splashscreen uses omxplayer to play sound, which bypasses any ALSA configuration, but EmulationStation (and most of the emulators) need a working ALSA config.
                            No, it's specific to the RPI bootloader, but there are other boot methods (U-Boot perhaps) that don't use the file.
                            • retropieuser555R
                              @mitu This is after adding the config.txt and overlays that the retroflag gpi. I can test it with the stock config.txt and original dpi24 overlay if that helps?
                              Pi 5 4GB
                              • PhilcommP
                                Philcomm
                                After further testing, I can't get either alsa nor pulse to work as sound drivers.
                                alsa doesn't find any sound card, thus is not able to play.
                                pulse can find the virtual sound card, but cannot output sound for some reason.
                                @mitu you are right, sound plays just fine with omxplayer.
                                I don't think it's the GPi cases' fault, but rather the drivers not able to play over GPIOs?
                                  You can do that, but - at best - you'll get sound only on the HDMI port, which is not what you want. But this configuration should get rid of the ALSA error and you'd have at least one card listed by aplay.
                                  • PhilcommP
                                    Philcomm
                                    @mitu you think it's worth a shot trying to manually create the asound.conf file?
                                    • PhilcommP
                                      Philcomm @retropieuser555
                                      Do you still have that image? My download is super slow, it takes another two hours to finish (around 60kb/s)
                                      • retropieuser555R
                                        @philcomm the recalbox beta? Yeah I've got it here, should I post their config or something from it?
                                        Pi 5 4GB
                                        • PhilcommP
                                          @retropieuser555 I wonder if there is any difference in the /boot/config.txt file compared to RetroPie. Also, is the md5 hash of /boot/overlays/pwm-audio-pi-zero.dtbo the same?
                                          • retropieuser555R
                                            @philcomm Here's there config file:-
                                            # Boot loader configuration                                                #
                                            # Warning: do not edit this file as it will be overwritten when upgrading! #
                                            # Using /etc/modules is deprecated and no longer supported on 4.4 kernel
                                            # So manually enable audio
                                            dtparam=audio=on
                                            # give a low resolution because tv had no enough time to initialize it
                                            boot_delay=3
                                            # disable boot rainbow
                                            disable_splash=1
                                            # default CEC name
                                            avoid_safe_mode=1
                                            kernel=boot/linux
                                            initramfs boot/initrd.gz
                                            # total amount of GPU memory
                                            gpu_mem_256=128
                                            gpu_mem_512=128
                                            gpu_mem_1024=448
                                            # your settings can be set in /boot/recalbox-user-config.txt
                                            include recalbox-user-config.txt
                                            # overclocking settings are automatically managed in this file
                                            # do not remove this line, nor edit the file
                                            include recalbox-oc-config.txt
                                            # Raise the first security limit up to 70° instead of 60° for pi3 and pi4
                                            [pi3]
                                            temp_soft_limit=70
                                            dtoverlay=vc4-kms-v3d
                                            include recalbox-crt-config.txt
                                            [pi4]
                                            temp_soft_limit=70
                                            # disable 4k resolution
                                            hdmi_pixel_freq_limit:0=200000000
                                            hdmi_pixel_freq_limit:1=200000000
                                            [board-type=0x12]
                                            # custom config
                                            [all]
                                            They don't seem to be using the pwm-audio-pi-zero.dtbo overlay in the config and it isn't in the overlay folders at all. Any ideas how they got this working? Guess can go onto their forum and ask them
                                            Pi 5 4GB
