    RPI 4 Model B 8GB Bluetooth not working
    bluetooth issueraspberry pi 4bbluetooth pi4
    3 Posts 3 Posters 599 Views
    • F
      fahadshery
      Hi Everyone,
      My bluetooth stopped working after a reboot.
      When I checked the status it showed this:
      pi@retropie:~ $ sudo systemctl status bluetooth
      ● bluetooth.service - Bluetooth service
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
         Active: inactive (dead)
           Docs: man:bluetoothd(8)
      I then did the following:
      sudo modprobe bluetooth
      sudo systemctl restart bluetooth.service
      It worked then:
         Active: active (running) since Thu 2021-11-04 10:12:56 GMT; 8s ago
       Main PID: 1157 (bluetoothd)
         Status: "Running"
          Tasks: 1 (limit: 4915)
         CGroup: /system.slice/bluetooth.service
                 └─1157 /usr/lib/bluetooth/bluetoothd
      Here are the dimes
      [   31.834544] vcc-sd: disabling
      [  257.847702] Bluetooth: Core ver 2.22
      [  257.847783] NET: Registered protocol family 31
      [  257.847792] Bluetooth: HCI device and connection manager initialized
      [  257.847812] Bluetooth: HCI socket layer initialized
      [  257.847825] Bluetooth: L2CAP socket layer initialized
      [  257.847846] Bluetooth: SCO socket layer initialized
      [  266.943562] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [  266.943573] Bluetooth: BNEP filters: protocol multicast
      [  266.943589] Bluetooth: BNEP socket layer initialized
      But it still can't see any bluetooth devices.
      What am I missing?
      cheers,
        Make sure you're fully updated - run the RetroPie update and say Yes when asked to update the OS/packages.
          MacGyver @fahadshery
          @fahadshery
          Also make sure that it's not a USB3 problem.
          RF interference from the USB3 ports on a Raspberry Pi 4 can knock out the 2.4Ghz Wifi band and the Bluetooth randomly. It can work fine one day and not the next.
          I would remove any USB3 cables (by putting them in the USB2 ports) and reboot.
          I was even forced to use a small USB2 extension cord on my NESPi case just to keep the USB3 SATA adapter stable. (it makes the device work at USB2 speeds)
          Better explained here:
          It's not Pi specific, but the bad shielding on certain USB3 devices on a Pi can make it worse.
