    Raspberry Pi 4 using 4 controllers Help
    pi4 8gblogitech 310arcade1up
    2 Posts 2 Posters 833 Views
      chuckwurt
      I have a Pi 4 8 gig using emulation station and it’s in an arcade 1up.
      I have the two arcade sticks from the 1up plugged into the usb 2.0 ports of the Pi. Then I have two Logitech controllers plugged into the 3.0 ports.
      When navigating the menus all controllers work fine. Once I enter a game to play, only the Logitech controllers work.
      I want it so they are all always working so I can use the arcade sticks when choosing arcade games, and Logitech controllers when I choose console games.
      Any suggestions?
      Thanks!
        @chuckwurt said in Raspberry Pi 4 using 4 controllers Help:
        Does this mean you're using RetroPie ? Please give more details about your system, as explained in https://retropie.org.uk/forum/topic/3/read-this-first.
        If the game is a max 2player game, then only the first 2 controllers will work. What game/emulator are you using ?
