    Problem with certain games with scummvm v2.5.0 on Pi3B+
    longest journeygrim fandangoscummvm
    7 Posts 3 Posters 673 Views
    • windgW
      windg
      Pi Model : Pi3b
      Power Supply used: Official
      RetroPie Version Used: 4.7.19
      Built From: Pi imager
      Controller used: official raspberry keyboard +mouse
      Emulator: scummvm (v2.5.0 from binary)
      I am trying to play The Longest Journey and GRim Fandango on a Pi3, after i choose the game to start, it throw back to the emulationstation. The same game roms are working fine on the Pi4.
      runcommnad.log:
      Parameters:
      Executing: bash "/home/pi/RetroPie/roms/scummvm/+Start ScummVM.sh"
      Virtual keyboard pack 'vkeybd_default' loaded successfully
      WARNING: Could not get GLSL version!
      Could not compile shader box.vertex: !
      User picked target 'tlj-win' (engine ID 'stark', game ID 'tlj')...
         Looking for a plugin supporting this target... Stark
      Debugger started, type 'exit' to return to the game.
      Type 'help' to see a little list of commands and variables.
      ERROR: Could not compile shader box.vertex: !
      /home/pi/RetroPie/roms/scummvm/+Start ScummVM.sh: line 4:  5573 Segmentation fault      /opt/retropie/emulators/scummvm/bin/scummvm --fullscreen --joystick=0 --extrapath="/opt/retropie/emulators/scummvm/extra" "$game"
      • retropieuser555R
        retropieuser555 @windg
        @windg I had a problem with scummvm on the pi zero for grim fandango, I had to change the 3d option to software instead of opengl. I think pi4 comes with opengl by default so maybe this is why it works there and not on your pi3?
        Pi 5 4GB
        windgW 1 Reply Last reply Reply Quote 1
        • windgW
          windg @retropieuser555
          @retropieuser555 said in Problem with certain games with scummvm v2.5.0 on Pi3B+:
          I follow your suggestion and Grim Fandango works fine, too bad Longest Journey doesn't support software mode at least it's working on Pi4. Thank you !
          • retropieuser555R
            @windg is your video output in HDMI? You might be able to get the opengl driver working on pi3 I think. It only doesn't work if you're using dpi video or something like that
            Pi 5 4GB
            windgW 1 Reply Last reply Reply Quote 0
            • windgW
              @retropieuser555 Yes im using HDMI, how i can enable opengl? It will affect the other emulator's?
              • retropieuser555R
                @windg potentially yes it will affect other things as it's not officially support on pi3 I think. I think you turn on vc4/kms driver from raspi-config. I'd definitely make a backup of your config.txt and other things as it might mess all kinds of things up on the pi 3, never tired it honestly.
                Pi 5 4GB
                mituM 1 Reply Last reply Reply Quote 1
                  mitu Global Moderator @retropieuser555
                  @retropieuser555 There's a FAQ entry about it.
