    Trying to mount roms folder from a Synology NAS using NFS
    nassynologyretropiemountnfs
    13 Posts 4 Posters 3.5k Views
    • ZangdaarrZ
      Zangdaarr
      I am trying to mount my roms from my Synology NAS and all I got in response is a "access denied".
      Here is my config on the NAS side (I created a Retropie user but with NFS I feel it's useless):
      And here is trying to mount:
      Where does the issue comes from ?
        Your screenshot where you add NFS permissions shows an IPv6 address, while the error in the mount command references an IPv4 network address - seems to me you've not allowed access to the share for RetroPie's IPv4 address.
        • GreyAreaUKG
          GreyAreaUK
          Since you have 'Enable advanced share permissions' ticked, make sure you go into them and make sure the permissions are correctly set in there. My recollection is that the permissions there override the 'normal' permissions, and are unset by default.
          Might be wrong, but worth a check.
          • ZangdaarrZ
            Zangdaarr
            I tried with the ipv6 and also the network alias "retropie" and both failed. I did not find how to get the ipv4 address for my retropie (and it's a bit upseting, in the past ipconfig was giving it)
            However on the mobaXterm screenshot, the ip is the one of my NAS, not the one of the pi. From my understanding, the NAS should receive a request from the provided ipv6 and accept it. It doesn't
            @ GreyAreaUK: I removed it since
            I also tried with cifs (using the retropie user created on the NAS) and it seems to work, except it does not find the <nasip>:/volume1/RetropieRoms folder (which exist and is case consistent)
            GreyAreaUKG mituM 2 Replies Last reply Reply Quote 0
            • GreyAreaUKG
              GreyAreaUK @Zangdaarr
              @zangdaarr ah - try removing the 'volume1' aspect of the path. I don't think that's actually visible outside the NAS itself.
              Edit: although to be clear, I don't think I've ever manually mounted a share from my Synology via the command line, so I could well be wrong.
              • windgW
                windg
                Does the router firewall affect the process ?
                With ifconfig from terminal you can see the ip.
                • GreyAreaUKG
                  GreyAreaUK
                  Try instead:
                  sudo mount -t cifs -o username=admin,password=password //10.1.1.30/RetropieRoms /home/pi/RetroPie/roms2
                  and replace your username/password and IP with the correct values for you. And I created a 'roms2' folder for testing.
                  Disclaimer: just tried it here on my own Synology. Seemed to work.
                  ZangdaarrZ 1 Reply Last reply Reply Quote 0
                    mitu Global Moderator @Zangdaarr
                    @zangdaarr said in Trying to mount roms folder from a Synology NAS using NFS:
                    Hm, if only there was a Show IP menu that would should you the address...
                    On Linux, there's no ipconfig, the corresponding command is ifconfig or ip -4 addr ls.
                    • ZangdaarrZ
                      Zangdaarr @mitu
                      @mitu I am not sure if your being sarcastic or not :D
                      I should be able to find the ipv4 address with the network mapping but I do not find the option in my windows settings.
                      ping always gave me the ipv4 address, I do not know why it suddenly changed.
                      Edit: found it: ping hostname -4
                      • ZangdaarrZ
                        Zangdaarr @GreyAreaUK
                        @greyareauk
                        Do you know why it does that ?
                        This one worked, don't really understand the difference between the two, and why it asked me for the password again
                        However, I'd like to understand what's the issue with NFS is
                        Edit: I understood it, unix does not like spaces between options. Both commands are working fine
                        • ZangdaarrZ
                          Zangdaarr @Zangdaarr
                          Fount it. For retropie:
                          • Do not enable asynchronous connections
                          • Even if the NAS allow for nfs v4, retropie won't allow it, so you need to use the nfsvers=3 option
                            I kind of was. You have a menu in the RetroPie system which is titled Show IP, which does exactly that - displays the network address of your RetroPie system.
                            Glad you got it sorted out in the end.
                            • ZangdaarrZ
                              Zangdaarr @mitu
                              @mitu said in Trying to mount roms folder from a Synology NAS using NFS:
                              Well I didn't know it ! Thanks for letting me know :)
