    Problem with Download RetroPie from homepage.
    retropieiso images
    8 Posts 2 Posters 1.1k Views
    • windgW
      windg
      Im trying to download RetroPie iso from homepage but it's not working, many hours now. Also weekly images are gone.
      • DougAD
        DougA
        Which version? I just tried to download the Pi 4B / Pi 400 image and it worked with no problems.
        • windgW
          windg
          I try all versions with the same results.
          DougAD 1 Reply Last reply Reply Quote 0
          • DougAD
            DougA @windg
            @windg What error do you get? Maybe your antivirus software is blocking downloading.
            windgW 1 Reply Last reply Reply Quote 0
            • windgW
              windg @DougA
              @douga said in Problem with Download RetroPie from homepage.:
              I click to download the iso but the download doesn't start. No antivirus, i am trying from linux machine and from android phone.
              • DougAD
                DougA @windg
                @windg I tried just now on an iPad, and earlier this week on a Windows PC. I also installed directly onto a Rasberry Pi that was already running Linux. All worked with no problems.
                • windgW
                  windg
                  I restart my router and everything is working fine again. Sorry for the inconvenience.
                  • DougAD
                    DougA @windg
                    @windg No inconvenience šŸ˜€. I’m glad you sorted out your problem.
