    Problem of Atomiswave and Naomi running
    retroarchatomiswavenaomi
    3 Posts 2 Posters 882 Views
    • H
      hanzohiro
      Hello thank you for looking at my post.
      I’m very new to use raspberry pi 4b and retropie.
      I’ve played retropie and change setting of retroarch and flycast. However,after I changed setting the Games of flycast Naomi Atomiswave games don’t run suddenly. When I select games, change to loading and turns black, then back to the list without any error messages.
      Retroarch also like that.
      I did anything such as update reinstalling flycast and reset all setting. But still cannot open.
      I can open other emulators but I cannot do only Naomi Atomiswave games.
      I’m a beginner to use raspberry pi4b, so please help me to run those games again.
      Sincerly
      Hanzohiro
        Try resetting the core options, you may have turned on something that's not supported on a Pi4. See https://retropie.org.uk/docs/RetroArch-Core-Options/#retroarch-core-optionscfg, the flycast settings are the lines starting with flycast or reicast - delete them from the files.
        • H
          hanzohiro @mitu
          @mitu thanks you so much for your advice!
          I will try
