    Star Wars Arcade 1993 shooting cursor problem
    mame2015cursorcontrollermap
    4 Posts 3 Posters 787 Views
      Prukogui
      Greetings,
      Star Wars Arcade 1993 game got it to work on a Raspberry Pi 4 4Gb. I use the Lr-MAME2015 emulator (I use swa.zip file and Retropie 4.7.19 version))
      It works fine but I have a problem with the controller (I use an ESM-9101 1.01 - EasySMX controller). I play with one player and when I move the ship the shooting cursor also move. I have seen videos where the shooting cursor is fixed in the center of the screen while the ship is moving.
      How can I do it?
      Thank you.
      PD. Sorry my bad english
        Did you change the Analog to Digital Type controller option in RetroArch's settings ? Are you moving using the D-Pad or one of the joysticks ?
          Prukogui @mitu
          @mitu I have used 2 retroarch options (digital and analog) without success. I have also tried in the MAME configuration (for the SWA game) putting the left joystick (I use the right joystick as a pedal) and, also, using D-Pad without success. In all options the shooter cursor moves.
          roslofR 1 Reply Last reply Reply Quote 0
          • roslofR
            roslof @Prukogui
            @prukogui from what I can tell, SWA on lr-2015 has permanent, broken controls. lr-2016 can be properly configured, but will run slower. lr-mame will run even slower, requires a different ROMset, but has more accurate emulation.
            2016 seems to run "okay-ish" up until the trench on the second scene, then there are a bunch of graphic anomalies.
            Wish I had better news, but there aren't many good solutions for SWA -- at least none that I could find.
