    No CD Audio tracks - lr_psx_rearmed
    cd audiops1 gameslr-pcsx-rearmed
    12 Posts 4 Posters 1.7k Views
      Stumaster
      Pi4 4GB
      Generic 5v 3a
      4.7.1
      Pre-made SD Card Image
      DualShock 4
      Emulator: lr-pcsx_rearmed
      Preample - re-making my DIY PS1 Classic from an older version of retropie - fresh image on new SD card
      I am not getting any CD audio data read from any .cue files (all the wipeout games specifically) using lr-pcsx_rearmed
      tried updating lr-pcsx_rearmed and reinstalling from binary
      The game files are known good and cd audio works on other devices.
      Using the same hardware the CD Audio works on my older build of retropie
      Compared the two runcommand logs in looks like retropie is not detecting the track data inside the cue file.
      Apologies for the log dump and thanks in advance
      OLD BUILD
      [libretro INFO] Loaded CD Image: /home/pi/RetroPie/roms/psx/WIPEOUT2.CUE[+cue].
      [libretro INFO] Track 01 (DATA) - Start 00:02:00, Length 08:11:29
      [libretro INFO] Track 02 (AUDIO) - Start 08:13:29, Length 05:53:00
      [libretro INFO] Track 03 (AUDIO) - Start 14:06:29, Length 04:29:66
      [libretro INFO] Track 04 (AUDIO) - Start 18:36:20, Length 05:33:37
      [libretro INFO] Track 05 (AUDIO) - Start 24:09:57, Length 05:21:49
      [libretro INFO] Track 06 (AUDIO) - Start 29:31:31, Length 06:07:23
      [libretro INFO] Track 07 (AUDIO) - Start 35:38:54, Length 04:41:52
      [libretro INFO] Track 08 (AUDIO) - Start 40:20:31, Length 04:50:55
      [libretro INFO] Track 09 (AUDIO) - Start 45:11:11, Length 06:08:23
      [libretro INFO] Track 10 (AUDIO) - Start 51:19:34, Length 04:41:27
      [libretro INFO] Track 11 (AUDIO) - Start 56:00:61, Length 06:14:50
      [libretro INFO] Track 12 (AUDIO) - Start 62:15:36, Length 05:14:61
      [libretro INFO] CD-ROM Label: WIPEOUT2
      [libretro INFO] CD-ROM ID: sles00327
      [libretro INFO] CD-ROM EXE Name: sles_003.27;1
      NEW BUILD
      [libretro INFO] Loaded CD Image: /home/pi/RetroPie/roms/psx/WIPEOUT2.CUE.
      LOG DUMP from NEW BUILD
      runcommand.log
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/pcsx_rearmed_libretro.so --config /opt/retropie/configs/psx/retroarch.cfg "/home/pi/RetroPie/roms/psx/WIPEOUT2.CUE" --verbose --appendconfig /dev/shm/retroarch.cfg
      [INFO] RetroArch 1.8.8 (Git 9552f87)
      [INFO] Redirecting save file to "/home/pi/RetroPie/roms/psx/WIPEOUT2.srm".
      [INFO] Redirecting save state to "/home/pi/RetroPie/roms/psx/WIPEOUT2.state".
      [INFO] Capabilities:  NEON VFPv3 VFPv4
      [INFO] Built: Nov  2 2020
      [INFO] Version: 1.8.8
      [INFO] Git: 9552f87
      [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-pcsx-rearmed/pcsx_rearmed_libretro.so"
      [INFO] [Overrides] core-specific overrides found at /home/pi/.config/retroarch/config/PCSX-ReARMed/PCSX-ReARMed.cfg.
      [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/PCSX-ReARMed/psx.cfg.
      [INFO] [Overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/PCSX-ReARMed/WIPEOUT2.cfg.
      [INFO] Config: appending config "/home/pi/.config/retroarch/config/PCSX-ReARMed/PCSX-ReARMed.cfg"
      [INFO] [Environ]: GET_LOG_INTERFACE.
      [INFO] [Environ]: SET_CONTROLLER_INFO.
      [INFO] [Environ]: GET_LANGUAGE: "0".
      [INFO] [Environ]: RETRO_ENVIRONMENT_SET_CORE_OPTIONS_INTL.
      [INFO] [Remaps]: remap directory: /opt/retropie/configs/psx/
      [libretro INFO] Memcard 2: disabled
      [libretro INFO] Starting PCSX-ReARMed
      [libretro INFO] Running PCSX Version 1.9 (Dec 15 2021).
      [libretro INFO] Init new dynarec
      [libretro INFO] testing if we can run recompiled code...
      [libretro INFO] test passed.
      [libretro INFO] Mapped (RAM/scrp/ROM/LUTs/TC):
      [libretro INFO] 0x80000000/0x1f800000/0x1fc00000/0x8000000/0xae534000
      [INFO] [Environ]: SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS".
      [libretro INFO] found BIOS file: SCPH1001.BIN
      [INFO] [Environ]: GET_CAN_DUPE: true
      [INFO] [Environ]: SET_DISK_CONTROL_EXT_INTERFACE.
      [INFO] [Environ]: GET_RUMBLE_INTERFACE.
      [INFO] [Environ]: PERFORMANCE_LEVEL: 6.
      [INFO] Content loading skipped. Implementation will load it on its own.
      [INFO] [Environ]: SET_INPUT_DESCRIPTORS:
      [INFO] [Environ]: SET_PIXEL_FORMAT: RGB565.
      [libretro INFO] RGB565 supported, using it
      [INFO] [Environ]: RETRO_ENVIRONMENT_SET_CORE_OPTIONS_DISPLAY.
      [libretro INFO] plugin: plugins/builtin_gpu
      [libretro INFO] plugin: plugins/builtin_spu
      [libretro INFO] plugin: plugins/builtin_pad
      [libretro INFO] Plugins loaded.
      [INFO] Skipping SRAM load..
      [INFO] Version of libretro API: 1
      [INFO] Compiled against API: 1
      [INFO] [Cheats]: Load game-specific cheatfile: /home/pi/.config/retroarch/cheats/PCSX-ReARMed/WIPEOUT2.cht
      [INFO] [Audio]: Set audio input rate to: 44100.00 Hz.
      [INFO] [Video]: Timings deviate too much. Will not adjust. (Display = 60.00 Hz, Game = 50.00 Hz)
      [INFO] [Video]: Video @ 1920x1080
      [INFO] [Video]: Starting threaded video driver ...
      [INFO] [DRM]: Found 1 connectors.
      [INFO] [DRM]: Connector 0 connected: yes
      [INFO] [DRM]: Connector 0 has 36 modes.
      [INFO] [DRM]: Connector 0 assigned to monitor index: #1.
      [INFO] [DRM]: Mode 0: (4096x2160) 4096 x 2160, 30 Hz
      [INFO] [DRM]: Mode 1: (4096x2160) 4096 x 2160, 30 Hz
      [INFO] [DRM]: Mode 2: (4096x2160) 4096 x 2160, 25 Hz
      [INFO] [DRM]: Mode 3: (4096x2160) 4096 x 2160, 24 Hz
      [INFO] [DRM]: Mode 4: (4096x2160) 4096 x 2160, 24 Hz
      [INFO] [DRM]: Mode 5: (3840x2160) 3840 x 2160, 30 Hz
      [INFO] [DRM]: Mode 6: (3840x2160) 3840 x 2160, 30 Hz
      [INFO] [DRM]: Mode 7: (3840x2160) 3840 x 2160, 25 Hz
      [INFO] [DRM]: Mode 8: (3840x2160) 3840 x 2160, 24 Hz
      [INFO] [DRM]: Mode 9: (3840x2160) 3840 x 2160, 24 Hz
      [INFO] [DRM]: Mode 10: (1920x1080) 1920 x 1080, 60 Hz
      [INFO] [DRM]: Mode 11: (1920x1080) 1920 x 1080, 60 Hz
      [INFO] [DRM]: Mode 12: (1920x1080i) 1920 x 1080, 60 Hz
      [INFO] [DRM]: Mode 13: (1920x1080i) 1920 x 1080, 60 Hz
      [INFO] [DRM]: Mode 14: (1920x1080) 1920 x 1080, 50 Hz
      [INFO] [DRM]: Mode 15: (1920x1080i) 1920 x 1080, 50 Hz
      [INFO] [DRM]: Mode 16: (1920x1080) 1920 x 1080, 30 Hz
      [INFO] [DRM]: Mode 17: (1920x1080) 1920 x 1080, 30 Hz
      [INFO] [DRM]: Mode 18: (1920x1080) 1920 x 1080, 25 Hz
      [INFO] [DRM]: Mode 19: (1920x1080) 1920 x 1080, 24 Hz
      [INFO] [DRM]: Mode 20: (1920x1080) 1920 x 1080, 24 Hz
      [INFO] [DRM]: Mode 21: (1280x1024) 1280 x 1024, 60 Hz
      [INFO] [DRM]: Mode 22: (1360x768) 1360 x 768, 60 Hz
      [INFO] [DRM]: Mode 23: (1152x864) 1152 x 864, 60 Hz
      [INFO] [DRM]: Mode 24: (1280x720) 1280 x 720, 60 Hz
      [INFO] [DRM]: Mode 25: (1280x720) 1280 x 720, 60 Hz
      [INFO] [DRM]: Mode 26: (1280x720) 1280 x 720, 50 Hz
      [INFO] [DRM]: Mode 27: (1024x768) 1024 x 768, 60 Hz
      [INFO] [DRM]: Mode 28: (800x600) 800 x 600, 60 Hz
      [INFO] [DRM]: Mode 29: (720x576) 720 x 576, 50 Hz
      [INFO] [DRM]: Mode 30: (720x576i) 720 x 576, 50 Hz
      [INFO] [DRM]: Mode 31: (720x480) 720 x 480, 60 Hz
      [INFO] [DRM]: Mode 32: (720x480) 720 x 480, 60 Hz
      [INFO] [DRM]: Mode 33: (640x480) 640 x 480, 60 Hz
      [INFO] [DRM]: Mode 34: (640x480) 640 x 480, 60 Hz
      [INFO] [DRM]: Mode 35: (720x400) 720 x 400, 70 Hz
      [INFO] [GL]: Found GL context: kms
      [INFO] [GL]: Detecting screen resolution 1920x1080.
      [INFO] [EGL] Found EGL client version >= 1.5, trying eglGetPlatformDisplay
      [INFO] [EGL]: EGL version: 1.4
      [INFO] [EGL]: Current context: 0xac2288a0.
      [INFO] [KMS]: New FB: 1920x1080 (stride: 7680).
      [INFO] [GL]: Vendor: Broadcom, Renderer: V3D 4.2.
      [INFO] [GL]: Version: OpenGL ES 3.1 Mesa 19.3.2.
      [INFO] [GL]: Using resolution 1920x1080
      [INFO] [GL]: Default shader backend found: glsl.
      [INFO] [Shaders]: preset directory: /home/pi/.config/retroarch/config
      [INFO] [Shaders]: preset directory: /opt/retropie/configs/psx/
      [INFO] [Shaders]: preset directory: /home/pi/.config/retroarch/shaders/presets
      [INFO] [Shader driver]: Using GLSL shader backend.
      [WARN] [GL]: Stock GLSL shaders will be used.
      [INFO] [GLSL]: Found GLSL vertex shader.
      [INFO] [GLSL]: Found GLSL fragment shader.
      [INFO] [GLSL]: Linking GLSL program.
      [INFO] [GL]: Using 4 textures.
      [INFO] [GL]: Loaded 1 program(s).
      [INFO] [udev]: Mouse #0 (/dev/input/event0).
      [INFO] [udev]: Mouse #1 (/dev/input/mouse0).
      [INFO] [udev]: Plugged pad: Sony Computer Entertainment Wireless Controller (1356:1476) on port #0.
      [INFO] [udev]: Pad #0 (/dev/input/event2) supports force feedback.
      [INFO] [udev]: Pad #0 (/dev/input/event2) supports 16 force feedback effects.
      [INFO] [Font]: Using font rendering backend: stb-unicode.
      [INFO] [Video]: Found display server: null
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xsal-level2-crt.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xsal.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/2xScaleHQ.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_lanczos4.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_phosphor.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/barrel-distortion_snes.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/Brighter-with_Contrast.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/bsnes_gamma_ramp.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-curvature-vertical.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-curvature.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi-vertical.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/crt-pi.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy-screen-grid.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/gameboy2.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/gba-color.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x&lcd3x.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x2.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x_lcd3x.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2x_phosphor.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2xwaterpaint.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq2xwaterpaintscanline.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq4x.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/hq4x_lcd3x.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/nds-color.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/nds.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/nedi.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/palm-color.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/phosphor.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/psp-color.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-2x-prescale.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-scanlines.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/sharp-bilinear-simple.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes2.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2x.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpaint.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpainthicontrast.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_hq2xwaterpaintscanline.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_lcd3x.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_phosphor.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_scanline.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/snes_waterpaint.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/stock.glsl"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/super-2xsai.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/super-eagle.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/vba-color.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/xbr-lv1-noblend.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_curve.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_curve_vertical.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_standard.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_crt_standard_vertical.glslp"
      [INFO] Found shader "/home/pi/.config/retroarch/shaders/zfast_lcd_standard.glslp"
      [INFO] [ALSA]: Using signed 16-bit format.
      [INFO] [ALSA]: Period size: 768 frames
      [INFO] [ALSA]: Buffer size: 3072 frames
      [INFO] [ALSA]: Can pause: no.
      [INFO] [Menu]: Found menu display driver: "gl".
      [INFO] [LED]: LED driver = 'null' 0x4b477c
      [INFO] [MIDI]: Initializing ...
      [INFO] [MIDI]: Input disabled.
      [INFO] [MIDI]: Output disabled.
      [INFO] [MIDI]: Initialized "alsa" driver.
      [libretro INFO] port: 1  device: standard
      [libretro INFO] port: 2  device: standard
      [libretro INFO] port: 3  device: standard
      [libretro INFO] port: 4  device: standard
      [libretro INFO] port: 5  device: standard
      [libretro INFO] port: 6  device: standard
      [libretro INFO] port: 7  device: standard
      [libretro INFO] port: 8  device: standard
      [INFO] Loading history file: [/opt/retropie/configs/psx/content_history.lpl].
      [INFO] Loading history file: [/opt/retropie/configs/psx/content_music_history.lpl].
      [INFO] Loading history file: [/opt/retropie/configs/psx/content_video_history.lpl].
      [INFO] Loading history file: [/opt/retropie/configs/psx/content_image_history.lpl].
      [INFO] Loading favorites file: [/opt/retropie/configs/psx/content_favorites.lpl].
      [INFO] SET_GEOMETRY: 640x478, aspect: 1.333.
      [INFO] SET_GEOMETRY: 320x256, aspect: 1.333.
      [INFO] SET_GEOMETRY: 640x256, aspect: 1.333.
      [INFO] SET_GEOMETRY: 320x240, aspect: 1.333.
      [INFO] [Overrides] configuration overrides unloaded, original configuration restored.
      [INFO] [Cheats]: Save game-specific cheatfile: /home/pi/.config/retroarch/cheats/PCSX-ReARMed/WIPEOUT2.cht
      [INFO] Saving RAM type #0 to "/home/pi/RetroPie/roms/psx/WIPEOUT2.srm".
      [INFO] Saved successfully to "/home/pi/RetroPie/roms/psx/WIPEOUT2.srm".
      [INFO] Content ran for a total of: 00 hours, 00 minutes, 48 seconds.
      [INFO] Unloading game..
      [INFO] Unloading core..
      [INFO] Unloading core symbols..
      [INFO] [Core Options]: Saved core options file to "/opt/retropie/configs/all/retroarch-core-options.cfg"
      [INFO] Threaded video stats: Frames pushed: 2339, Frames dropped: 85.
      ari64_reset
      PCSX-ReARMed.cfg
      accessibility_narrator_speech_speed = "5"
      ai_service_url = "http://localhost:4404/"
      aspect_ratio_index = "23"
      assets_directory = "~/.config/retroarch/assets"
      audio_driver = "alsa"
      audio_enable = "true"
      audio_latency = "64"
      audio_max_timing_skew = "0.050000"
      audio_out_rate = "48000"
      audio_rate_control = "true"
      audio_resampler = "sinc"
      audio_resampler_quality = "2"
      audio_sync = "true"
      auto_overrides_enable = "true"
      auto_screenshot_filename = "true"
      auto_shaders_enable = "true"
      builtin_imageviewer_enable = "true"
      builtin_mediaplayer_enable = "true"
      camera_driver = "null"
      cheat_database_path = "~/.config/retroarch/cheats"
      cheevos_richpresence_enable = "true"
      content_database_path = "~/.config/retroarch/database/rdb"
      content_favorites_size = "200"
      content_history_size = "200"
      content_runtime_log = "true"
      content_show_add = "true"
      content_show_favorites = "true"
      content_show_history = "true"
      content_show_images = "true"
      content_show_music = "true"
      content_show_netplay = "true"
      content_show_playlists = "true"
      content_show_settings = "true"
      content_show_video = "true"
      core_assets_directory = "~/.config/retroarch/downloads"
      core_set_supports_no_game_enable = "true"
      core_updater_auto_extract_archive = "true"
      core_updater_buildbot_assets_url = "http://buildbot.libretro.com/assets/"
      crt_switch_resolution_super = "2560"
      crt_video_refresh_rate = "60.000000"
      cursor_directory = "~/.config/retroarch/database/cursors"
      custom_viewport_height = "960"
      custom_viewport_width = "1280"
      custom_viewport_x = "320"
      custom_viewport_y = "60"
      desktop_menu_enable = "true"
      discord_app_id = "475456035851599874"
      driver_switch_enable = "true"
      fps_update_interval = "256"
      frontend_log_level = "1"
      game_specific_options = "true"
      history_list_enable = "true"
      input_analog_sensitivity = "1.000000"
      input_bind_hold = "2"
      input_bind_timeout = "5"
      input_descriptor_label_show = "true"
      input_driver = "x"
      input_duty_cycle = "3"
      input_overlay = "~/.config/retroarch/overlay/systems/psx_overlay.cfg"
      input_overlay_enable = "true"
      input_overlay_enable_autopreferred = "true"
      input_overlay_hide_in_menu = "true"
      input_overlay_opacity = "0.700000"
      input_overlay_scale = "1.000000"
      input_overlay_show_mouse_cursor = "true"
      input_player10_joypad_index = "9"
      input_player11_joypad_index = "10"
      input_player12_joypad_index = "11"
      input_player13_joypad_index = "12"
      input_player14_joypad_index = "13"
      input_player15_joypad_index = "14"
      input_player16_joypad_index = "15"
      input_player2_joypad_index = "1"
      input_player3_joypad_index = "2"
      input_player4_joypad_index = "3"
      input_player5_joypad_index = "4"
      input_player6_joypad_index = "5"
      input_player7_joypad_index = "6"
      input_player8_joypad_index = "7"
      input_player9_joypad_index = "8"
      input_poll_type_behavior = "2"
      input_remap_binds_enable = "true"
      input_turbo_period = "6"
      joypad_autoconfig_dir = "~/.config/retroarch/autoconfig"
      keyboard_gamepad_enable = "true"
      keyboard_gamepad_mapping_type = "1"
      led_driver = "null"
      libretro_directory = "~/.config/retroarch/cores"
      libretro_info_path = "~/.config/retroarch/cores"
      libretro_log_level = "1"
      load_dummy_on_core_shutdown = "true"
      location_driver = "null"
      log_dir = "~/.config/retroarch/logs"
      materialui_auto_rotate_nav_bar = "true"
      materialui_dual_thumbnail_list_view_enable = "true"
      materialui_icons_enable = "true"
      materialui_landscape_layout_optimization = "1"
      materialui_menu_color_theme = "9"
      materialui_show_nav_bar = "true"
      materialui_thumbnail_background_enable = "true"
      materialui_thumbnail_view_landscape = "2"
      materialui_thumbnail_view_portrait = "1"
      menu_battery_level_enable = "true"
      menu_core_enable = "true"
      menu_enable_widgets = "true"
      menu_font_color_blue = "255"
      menu_font_color_green = "255"
      menu_font_color_red = "255"
      menu_footer_opacity = "1.000000"
      menu_framebuffer_opacity = "0.900000"
      menu_header_opacity = "1.000000"
      menu_horizontal_animation = "true"
      menu_insert_disk_resume = "true"
      menu_mouse_enable = "true"
      menu_navigation_browser_filter_supported_extensions_enable = "true"
      menu_navigation_wraparound_enable = "true"
      menu_pause_libretro = "true"
      menu_rgui_full_width_layout = "true"
      menu_savestate_resume = "true"
      menu_scale_factor = "1.000000"
      menu_shader_pipeline = "2"
      menu_show_configurations = "true"
      menu_show_dump_disc = "true"
      menu_show_help = "true"
      menu_show_information = "true"
      menu_show_latency = "true"
      menu_show_load_content = "true"
      menu_show_load_core = "true"
      menu_show_load_disc = "true"
      menu_show_overlays = "true"
      menu_show_quit_retroarch = "true"
      menu_show_reboot = "true"
      menu_show_rewind = "true"
      menu_show_shutdown = "true"
      menu_show_sublabels = "true"
      menu_show_video_layout = "true"
      menu_throttle_framerate = "true"
      menu_thumbnails = "3"
      menu_ticker_smooth = "true"
      menu_ticker_speed = "2.000000"
      menu_ticker_type = "1"
      menu_timedate_enable = "true"
      menu_timedate_style = "11"
      menu_wallpaper_opacity = "0.300000"
      menu_widget_scale_auto = "true"
      menu_widget_scale_factor = "1.000000"
      menu_widget_scale_factor_windowed = "1.000000"
      menu_xmb_thumbnail_scale_factor = "100"
      midi_driver = "alsa"
      midi_input = "Off"
      midi_output = "Off"
      midi_volume = "100"
      netplay_allow_slaves = "true"
      netplay_check_frames = "600"
      netplay_ip_port = "55435"
      netplay_mitm_server = "nyc"
      netplay_nat_traversal = "true"
      netplay_public_announce = "true"
      netplay_share_analog = "1"
      netplay_share_digital = "1"
      network_cmd_port = "55355"
      network_remote_base_port = "55400"
      overlay_directory = "~/.config/retroarch/overlay"
      ozone_menu_color_theme = "1"
      ozone_sort_after_truncate_playlist_name = "true"
      ozone_truncate_playlist_name = "true"
      pause_nonactive = "true"
      playlist_directory = "~/.config/retroarch/playlists"
      playlist_entry_remove_enable = "1"
      playlist_entry_rename = "true"
      playlist_show_sublabels = "true"
      playlist_sort_alphabetical = "true"
      quick_menu_show_add_to_favorites = "true"
      quick_menu_show_cheats = "true"
      quick_menu_show_close_content = "true"
      quick_menu_show_controls = "true"
      quick_menu_show_download_thumbnails = "true"
      quick_menu_show_information = "true"
      quick_menu_show_options = "true"
      quick_menu_show_recording = "true"
      quick_menu_show_reset_core_association = "true"
      quick_menu_show_restart_content = "true"
      quick_menu_show_resume_content = "true"
      quick_menu_show_save_content_dir_overrides = "true"
      quick_menu_show_save_core_overrides = "true"
      quick_menu_show_save_game_overrides = "true"
      quick_menu_show_save_load_state = "true"
      quick_menu_show_set_core_association = "true"
      quick_menu_show_shaders = "true"
      quick_menu_show_start_recording = "true"
      quick_menu_show_start_streaming = "true"
      quick_menu_show_streaming = "true"
      quick_menu_show_take_screenshot = "true"
      quick_menu_show_undo_save_load_state = "true"
      record_driver = "ffmpeg"
      rewind_buffer_size_step = "10"
      rgui_background_filler_thickness_enable = "true"
      rgui_border_filler_enable = "true"
      rgui_border_filler_thickness_enable = "true"
      rgui_config_directory = "~/.config/retroarch/config"
      rgui_menu_color_theme = "4"
      rgui_particle_effect_speed = "1.000000"
      run_ahead_frames = "1"
      run_ahead_secondary_instance = "true"
      savestate_file_compression = "true"
      screenshot_directory = "~/.config/retroarch/screenshots"
      settings_show_achievements = "true"
      settings_show_ai_service = "true"
      settings_show_audio = "true"
      settings_show_configuration = "true"
      settings_show_core = "true"
      settings_show_directory = "true"
      settings_show_drivers = "true"
      settings_show_frame_throttle = "true"
      settings_show_input = "true"
      settings_show_latency = "true"
      settings_show_logging = "true"
      settings_show_network = "true"
      settings_show_onscreen_display = "true"
      settings_show_playlists = "true"
      settings_show_power_management = "true"
      settings_show_recording = "true"
      settings_show_saving = "true"
      settings_show_user = "true"
      settings_show_user_interface = "true"
      settings_show_video = "true"
      slowmotion_ratio = "3.000000"
      suspend_screensaver_enable = "true"
      threaded_data_runloop_enable = "true"
      thumbnails_directory = "~/.config/retroarch/thumbnails"
      ui_companion_start_on_boot = "true"
      ui_menubar_enable = "true"
      video_allow_rotate = "true"
      video_aspect_ratio = "-1.000000"
      video_crop_overscan = "true"
      video_driver = "gl"
      video_font_enable = "true"
      video_force_aspect = "true"
      video_fullscreen_x = "1920"
      video_fullscreen_y = "1080"
      video_layout_directory = "~/.config/retroarch/layouts"
      video_layout_enable = "true"
      video_max_swapchain_images = "3"
      video_message_pos_x = "0.050000"
      video_message_pos_y = "0.050000"
      video_msg_bgcolor_opacity = "1.000000"
      video_record_quality = "4"
      video_record_scale_factor = "1"
      video_record_threads = "2"
      video_scale = "3.000000"
      video_shader_dir = "~/.config/retroarch/shaders"
      video_stream_port = "56400"
      video_stream_quality = "10"
      video_stream_scale_factor = "1"
      video_vsync = "true"
      video_window_opacity = "100"
      video_window_show_decorations = "true"
      video_windowed_fullscreen = "true"
      video_windowed_position_height = "720"
      video_windowed_position_width = "1280"
      wifi_driver = "null"
      xmb_alpha_factor = "75"
      xmb_menu_color_theme = "4"
      .CUE
      FILE "WIPEOUT2.BIN" BINARY
        TRACK 01 MODE2/2352
          INDEX 01 00:00:00
        TRACK 02 AUDIO
          PREGAP 00:02:00
          INDEX 01 08:09:29
        TRACK 03 AUDIO
          INDEX 00 14:00:29
          INDEX 01 14:02:29
        TRACK 04 AUDIO
          INDEX 00 18:30:20
          INDEX 01 18:32:20
        TRACK 05 AUDIO
          INDEX 00 24:03:57
          INDEX 01 24:05:57
        TRACK 06 AUDIO
          INDEX 00 29:25:31
          INDEX 01 29:27:31
        TRACK 07 AUDIO
          INDEX 00 35:32:54
          INDEX 01 35:34:54
        TRACK 08 AUDIO
          INDEX 00 40:14:31
          INDEX 01 40:16:31
        TRACK 09 AUDIO
          INDEX 00 45:05:11
          INDEX 01 45:07:11
        TRACK 10 AUDIO
          INDEX 00 51:13:34
          INDEX 01 51:15:34
        TRACK 11 AUDIO
          INDEX 00 55:54:61
          INDEX 01 55:56:61
        TRACK 12 AUDIO
          INDEX 00 62:09:36
          INDEX 01 62:11:36
        Stumaster
        Update - just made a fresh image of 4.7.1 - minimal setup - bios + roms.
        Same issue
        going to try 4.6 to see if issue is 4.7.1 specific
          Stumaster
          Same on 4.6. and re-ripped the bin cue files.
          I cant understand how exactly the same files in practically the same hardware can have such a vast difference - only real change has been the microSD card (from 8GB to 64GB).
          Genos98G 1 Reply Last reply Reply Quote 0
          • Genos98G
            Genos98 @Stumaster
            @stumaster I remember having this issue where tracks wont play on a ps1 game back in the day when I burn it into cd. What I would do is just convert multiple tracks games into just one .bin file using cdmage. This solves my issues with the audio tracks and worth a try in your case.
            https://m.emuparadise.me/links-and-downloads/General_CD_Utils/CDmage_1.02.1_Beta_5/20
            Another option is converting your cue and bin to compressed file format like chd, pbp, or m3u.
              I think the .cue file is problematic - a proper cue/bin rip will have a .bin file for each track (data + audio):
              FILE "WipEout 2097 (Europe) (Track 01).bin" BINARY
                TRACK 01 MODE2/2352
                  INDEX 01 00:00:00
              FILE "WipEout 2097 (Europe) (Track 02).bin" BINARY
                TRACK 02 AUDIO
                  INDEX 00 00:00:00
                  INDEX 01 00:02:00
              FILE "WipEout 2097 (Europe) (Track 03).bin" BINARY
                TRACK 03 AUDIO
                  INDEX 00 00:00:00
                  INDEX 01 00:02:00
              FILE "WipEout 2097 (Europe) (Track 04).bin" BINARY
                TRACK 04 AUDIO
                  INDEX 00 00:00:00
                  INDEX 01 00:02:00
              FILE "WipEout 2097 (Europe) (Track 05).bin" BINARY
                TRACK 05 AUDIO
                  INDEX 00 00:00:00
                  INDEX 01 00:02:00
              etc...
              With this .cue file and all the .bin files there's no issue loading the game's audio:
              [libretro INFO] Loaded CD Image: /home/pi/RetroPie/roms/psx/WipEout 2097 (Europe).cue[+cue].
              [libretro INFO] Track 01 (DATA) - Start 00:02:00, Length 08:09:29
              [libretro INFO] Track 02 (AUDIO) - Start 08:13:29, Length 05:51:00
              [libretro INFO] Track 03 (AUDIO) - Start 14:06:29, Length 04:27:66
              [libretro INFO] Track 04 (AUDIO) - Start 18:36:20, Length 05:31:37
              [libretro INFO] Track 05 (AUDIO) - Start 24:09:57, Length 05:19:49
              [libretro INFO] Track 06 (AUDIO) - Start 29:31:31, Length 06:05:23
              [libretro INFO] Track 07 (AUDIO) - Start 35:38:54, Length 04:39:52
              [libretro INFO] Track 08 (AUDIO) - Start 40:20:31, Length 04:48:55
              [libretro INFO] Track 09 (AUDIO) - Start 45:11:11, Length 06:06:23
              [libretro INFO] Track 10 (AUDIO) - Start 51:19:34, Length 04:39:27
              [libretro INFO] Track 11 (AUDIO) - Start 56:00:61, Length 06:12:50
                Stumaster
                This is the first i have heard about seperate .bin for each track - every game i have ripped from disc has always been a single .bin .cue - i thought the whole idea of the .cue was to point to specific sectors (tracks)?
                Wouldnt having seperate .bin files end up with an emulation station full of entries for each .bin?
                @Genos98 converting the files to .chd works - thanks!- just curious how converting to .chd from exact same .bin/.cue is fine but using the same .bin cue on their own doesnt
                [libretro INFO] Loaded CD Image: /home/pi/RetroPie/roms/psx/WIPEOUT2.chd[+chd].
                [libretro INFO] Track 03 (AUDIO) - Start 14:06:29, Length 04:31:66
                [libretro INFO] Track 04 (AUDIO) - Start 18:38:20, Length 05:35:37
                [libretro INFO] Track 05 (AUDIO) - Start 24:13:57, Length 05:23:49
                [libretro INFO] Track 06 (AUDIO) - Start 29:37:31, Length 06:09:23
                [libretro INFO] Track 07 (AUDIO) - Start 35:46:54, Length 04:43:52
                [libretro INFO] Track 08 (AUDIO) - Start 40:30:31, Length 04:52:55
                [libretro INFO] Track 09 (AUDIO) - Start 45:23:11, Length 06:10:23
                [libretro INFO] Track 10 (AUDIO) - Start 51:33:34, Length 04:43:27
                [libretro INFO] Track 11 (AUDIO) - Start 56:16:61, Length 06:16:50
                [libretro INFO] Track 12 (AUDIO) - Start 62:33:36, Length 05:16:61
                  Not sure how are you ripping your CDs, but the Redump project always uses this format - see http://redump.org/disc/1041/.
                  No, since .bin files are not displayed by EmulationStation by default - see https://retropie.org.uk/docs/Saturn/#why-dont-my-bin-or-iso-files-show-up.
                    Stumaster @mitu
                    I use imgburn - do you have any recommendations for ripping software? imgburn doesnt seem to have any options to seperate out each tracks into seperate .bins
                    mituM sirhenrythe5thS 2 Replies Last reply Reply Quote 0
                      mitu Global Moderator @Stumaster
                      @stumaster You can use the recommended setup from Redump.org - http://wiki.redump.org/index.php?title=Disc_Dumping_Guide_(MPF).
                      • sirhenrythe5thS
                        sirhenrythe5th @Stumaster
                        @stumaster a propos recommendations: as far as PSX-Emulators are concerned lr-duckstation is the most recommended emulator in our days. Uses the same file-types, so you wont need to convert your isos again ;)
                        RetroRatio: 1.88
                        Started Games beaten: 2,47%
                        Site Rank: 4382/93743 ranked users (TOP 4.76%)
                        Last seen in [The Legend of Zelda: Lost in Time (HACK) [N64], exploring Hyrule at Night]
                        • Genos98G
                          Genos98 @Stumaster
                          @stumaster converting to chd would also automatically look for and combine multiple tracks of a game as long as it's in the same folder. So lets say you have tekken with 12 tracks on it in the same folder, then they will all be combined and included in the chd file that will be created. That's the reason why converting fixed your issue.
                            Stumaster
                            All good now.
                            Thanks to everyone for your help.
