    Operation Wolf (Sega Master System) with a standard controller
    master systemlightgun
    2 Posts 2 Posters 949 Views
    • retrotartaR
      retrotarta
      I can't seem to make it work with one, all the roms I've tried are Light Phaser only, there's never a cursor on screen to use with the controller. Isn't the game supposed to offer the alternative originally without needing to hack it?
      Many thanks and best regards.
        According to the manual, it can be played with the Light Phaser or the Controller, but the controller should be in Port 2.
        You can choose, in the Port 1/2 controls sub-menus, to which console port the controllers are mapped. If you map the 1st controller to Port 2 and vice-versa (2nd controller to Port 1), this will enable you to play using the controller, without a light gun device - the game will detect you have the controller in the 2nd port and start without light gun support.
