    lr-px68k Multidisk games problem
    lr-px68kmultidisc
    27 Posts 2 Posters 3.3k Views
      mitu Global Moderator @KrinaSam
      @krinasam said in lr-px68k Multidisk games problem:
      Can you show me yours runcommand.log file?
      It should look similar to this, including the messages showing the core shutdown:
      [INFO] [Core]: Unloading core..
      [INFO] [Core]: Unloading core symbols..
      Your log stops before the core is loaded/game is started.
        KrinaSam @mitu
        @mitu I tried to run another system (psx) and runcommand.log looks like yours. It looks like lr-px68k doesn't write to the runcommand.log file.
        in retroarch/options/logging i set verbose logging and logging to file.
        /opt/retropie/configs.hdmi/all/retroarch/logs/retroarch.log
        this is log when game won't run:
        link text
        and this is log file when i removed read permission, and game loads correct:
        link text
        I don't see any difference
          I suspect the the folder override you saved for x68000 has an impact on the behavior and the logging file being smaller:
          [INFO] [Overrides]: Content dir-specific overrides found at "/home/pi/.config/retroarch/config/PX68K/x68000.cfg".
          Can you try renaming the file, just for testing, to see if this changes the core's behavior ?
            KrinaSam @mitu
            @mitu you were right. after deleting a file, the log is saved correctly. But this does not fix the problem with the sram.dat file
              That was kind of expected and it looks like a core issue.
              The logs show that the disc images are properly set into FDD0/FDD1, so the only explanation for your problem would be that the sram.dat is corrupted between games.
              As a workaround, you could delete the sram.dat file between runs, using an onstart script for runcommand.
                KrinaSam @mitu
                @mitu Thank you for help. Could you please help me with the nds drastic emulator in my other thread?link text
                  @krinasam I'm not familiar with drastic, maybe other forum user has an idea.
