    [solved] Sd card location using usbromservice?
    usbromservice
    4 Posts 2 Posters 430 Views
      Stuffu
      I’m using a 16gb sd-card together with a an external disk using usbromservice. Now, the sd-card is getting very close to full and all roms, scrapes etc is on the external drive. Something must be duplicates and I haven’t found a way accessing the sd-card to have a look.
      In /media i was hoping to find the sd-card but the only thing of interest is usb1 which is my external drive.
      Can someone point me in a direction?
      windgW 1 Reply Last reply Reply Quote 0
      • windgW
        windg @Stuffu
        @stuffu
        I think the correct path is: /home/pi/RetroPie/roms
          Stuffu @windg
          @windg thanks for the reply, I was more looking for path to the actual sd-card when using usbromservice. I could pull the external drive but I would like to have it mounted for comparison.
            Stuffu
            Booted up on sd-card only and found a huge pile of cache files from skyscraper. Purged it and that fixed the issue.
