    Problems with diagonal-controls with my joysticks
    joysticksanalogcontrols
    2 Posts 2 Posters 462 Views
      Manuel_Pieper
      Hey there!
      I bought a 2-Player Arcade Joysticks and Button-Set. (Fosiya 2 Player Arcade Joystick LED Chrome Buttons)
      Here is a link: https://www.amazon.com/-/de/dp/B07WRGXJ25/ref=sr_1_6?keywords=fosiya%2Barcade%2Bbuttons&qid=1642938712&sprefix=fosiya%2Ba%2Caps%2C155&sr=8-6&th=1
      And they are all working, but when I play games that support diagonal-movement it doesnt work as smooth as it should be.
      So i tested the input of my controllers with "jstest" and some Axes are more hardly to get the desired input from.
      I have the problem with both of my controller, so i dont think that they are broken. Is there something like a sensivity-parameter to control those axes more with ease?
      Or does someone have similar issues?
      Any ideas are appreciated!
      Greetings from germany!
      PsychoKillerrP 1 Reply Last reply Reply Quote 0
      • PsychoKillerrP
        PsychoKillerr @Manuel_Pieper
        @manuel_pieper have you checked your restrictor plate under the joystick? If its adjustable, maybe its in the 4 way profile instead of the 8 way?
